Autogyro Disk Loading Question
Old April 27th 18, 02:00 AM posted to rec.aviation.rotorcraft
Default Autogyro Disk Loading Question
On Wednesday, 19 March 1997 21:00:00 UTC+13, Stephen Lund wrote:
I am wondering what might be the theoretical and/or practical MINIMUM
disk loading for an autogyro and what might be the characteristics or
dificulties in flying such a lightly loaded disk?
Steve Lund
If you mean wing-loading in cruise - it is a trade-off with flight speed. The bigger the disc, the lower the disc loading, the higher the hover-efficiency (or whatever you want to call it in autorotation - I don't think the momentum argument changes) but the lower the flight speed. Also, there are practical limits to rotor diameter to do with blade-droop and ground-handling. Most designs seem to be around 10 kg/m2. Above that the efficiency falls off.....
WTB Ilec SC7 MacCready disk SoaringXCellence Soaring 1 July 22nd 14 04:47 AM
hydraulic disk brake upgrade shkdriver Soaring 2 June 27th 13 06:41 PM
Disk vs Drum on Trailer Tony[_5_] Soaring 20 June 25th 10 05:17 AM
UPDATE: Auslogics Disk Defrag v3.1.1.80 Franklin[_19_] Piloting 1 December 6th 09 05:04 PM
disk loading Roopah Vi Tam Rotorcraft 1 September 9th 04 06:45 PM
