Oudie question
Old July 3rd 18, 02:15 AM posted to rec.aviation.soaring
Default Oudie question
I attempted to update my Oudie 2 to v8.03 yesterday and it seems to have broken it.
It now starts with an error window:
Application error
Not found Applitaion!
Please install it from SD/MMC.
Does anyone have any suggestions? I have tried reinstalling the update and even copying back old backups of ResidentFlash and SDMMC.
Old July 3rd 18, 03:34 PM posted to rec.aviation.soaring
2G
Application error
There is a hard reset button on the back of the Oudie - try pressing that with a paper clip.
Tom
Old July 3rd 18, 06:22 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Send a note off to Naviter via https://www.naviter.com/contact-us/. They are pretty responsive.
Old July 3rd 18, 10:09 PM posted to rec.aviation.soaring
Application error
Does it eventually boot and run SeeYou? If so, check to make sure you have your current registration key entered into the Oudie.
Old July 3rd 18, 11:09 PM posted to rec.aviation.soaring
Thanks. The Oudie needed a reload of the OS apparently.
Jost from Naviter was very helpful.
Old July 4th 18, 06:49 PM posted to rec.aviation.soaring
Yep, they are good people at Naviter.
How did you reload the OS (as different than reloading SeeYou Mobile)? Hard reset?
Thanks.
Old July 4th 18, 08:21 PM posted to rec.aviation.soaring
Paul Remde
Hi John,
It's a process. It is very rare that it is necessary - usually when a customer accidentally deletes files in the Oudie memory. I've helped few customers through it. It is not difficult, but requires PC file management skills.
Best Regards,
Paul Remde
On Wednesday, July 4, 2018 at 12:49:13 PM UTC-5, OHM Ω http://aviation.derosaweb.net wrote:
Thanks.
Old July 4th 18, 09:06 PM posted to rec.aviation.soaring
On Thursday, 5 July 2018 05:49:13 UTC+12, OHM Ω http://aviation.derosaweb.net wrote:
Thanks.
Yes.
They send the files to reinstall the system and step-by-step instructions. It is all quite simple really.
I don't know what went wrong. It might have been something to do with power as it then wouldn't charge and kept restarting, but that is just guessing. It might need a new battery, but haven't used it since.
Thanks to Paul Remde for pointing me in the right direction.
Old August 6th 18, 06:45 PM posted to rec.aviation.soaring
Em quarta-feira, 4 de julho de 2018 17:06:40 UTC-3, escreveu:
Thanks.
Yes.
They send the files to reinstall the system and step-by-step instructions.. It is all quite simple really.
Hi,
I Has the same problem.
Is possible to send to me the instructions and the file to restart system for claudio_haddad @ yahoo.com.br ?
Thank you,
Claudio
oudie/s80 question Del Jensen Soaring 11 September 17th 17 02:36 AM
Oudie Question Roger Fowler[_3_] Soaring 4 May 29th 13 11:34 PM
Question for Oudie users [email protected] Soaring 9 September 13th 12 02:17 PM
Oudie - ConnectMe question [email protected] Soaring 9 August 9th 10 04:18 PM
