Tracking from WGC in Poland
Old July 9th 18, 02:04 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Tracking from WGC in Poland
Anyone else having trouble viewing the live tracking? Error message says "Sorry...."
P3
Old July 9th 18, 02:16 PM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
P3
Try here
http://soarscore.com/competitions/wgc2018pl/
But that one is messed up too.. the comp numbers for 15m seem to be the ones from Standard class.
Old July 9th 18, 02:48 PM posted to rec.aviation.soaring
Ross[_3_]
There seems to have been a major step backwards in technology for this comp.
No info about time on task, speeds etc and not at all interesting to watch as the coverage is poor.
Was looking forward to this one, but maybe the Czech guys have it sorted better
Old July 9th 18, 04:05 PM posted to rec.aviation.soaring
Organisers are currently learning how to make proper use of live tracking. It requires significant lead time to set this up properly for an event like WGC.
Technologywise, the folks in Poland are using a similar OGN-based approach like at the SGP in Chile last winter (the best way to got in my opinion). But live scoring is different at an WGC compared to a Grand-Prix competition.. Some implementations of this have been done in the past, but as an organizer you need to have the necessary IT knowledge in your team to make use of it. This has not been the case with previous competitions.
For the WGC in Germany in 2020, we are currently running some tests already this year to make sure everything works at the worlds (e.g. at current Lüsse competition: http://lilienthalglide.de/wp-content...vescore_1.png).
Old July 9th 18, 05:27 PM posted to rec.aviation.soaring
krasw
On Monday, 9 July 2018 18:05:09 UTC+3, wrote:
Organisers are currently learning how to make proper use of live tracking.. It requires significant lead time to set this up properly for an event like WGC.
Technologywise, the folks in Poland are using a similar OGN-based approach like at the SGP in Chile last winter (the best way to got in my opinion). But live scoring is different at an WGC compared to a Grand-Prix competition. Some implementations of this have been done in the past, but as an organizer you need to have the necessary IT knowledge in your team to make use of it. This has not been the case with previous competitions.
There is not enough good OGN receivers in competition area, that is clear. That's why tracking does not work. Even one good receiver in Ostrow would make a huge difference.
It should be noted that some pilots choose to turn their flarm off while flying.
Old July 9th 18, 05:42 PM posted to rec.aviation.soaring
Is the Club Class & Standard Class handicapped at the WC in Poland?
WH
Old July 9th 18, 08:30 PM posted to rec.aviation.soaring
Dan Daly[_2_]
WH
Standard - no.
Club - yes, in accordance with https://www.fai.org/sites/default/files/sc3ah_2018a.pdf "IGC PROCEDURES FOR HANDICAPPED CLASSES" - handicaps in Appendix 1.
Old July 9th 18, 05:50 PM posted to rec.aviation.soaring
There is not enough good OGN receivers in competition area, that is clear.. That's why tracking does not work. Even one good receiver in Ostrow would make a huge difference.
Ensuring a good receiver coverage is one of the items that require significant lead times. OGN experts developed a long range receiver setup which is available at less than 200€ (e.g. he http://ognrange.onglide.com/#EDOV,ma...f f,circles;), but it takes some efforts and collaboration from other clubs to distribute these throughout the countryside.
During the last IGC meeting, a year 1 proposal was adopted to separate collision avoidance like FLARM from tracking hardware. This is aimed towards preventing pilots from switching off their FLARM units in order to hide themselves in tracking. Separate OGN trackers will have to be used. They are in the works and start to be available at reasonable costs (some were built in Poland already).
The trackers that were used at Benalla WGC unfortunately proved to be completely unreliable in European networks.
Old July 9th 18, 07:03 PM posted to rec.aviation.soaring
krasw
We have built OGN stations that get reliable 80-100km range, current Ostrow station range is 30 km. Hardware matters.
Old July 10th 18, 12:33 PM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
Day 3 cancelled
Good News on Delorme InReach (2 min tracking and altitude vs. Spot w/10 min tracking and no altitude) Sean F (F2) Soaring 34 February 24th 13 12:46 AM
F-16 from Poland DraX Aviation Photos 8 August 24th 07 09:25 AM
F-16 from Poland Marta Aviation Photos 8 November 13th 06 10:08 PM
Poland and U.K. iowa Military Aviation 16 October 19th 03 08:30 PM
Poland Grantland Military Aviation 3 October 15th 03 07:34 PM
