grob main wheel and brake disk
Old July 17th 18, 04:38 PM posted to rec.aviation.soaring
Scott Williams
Default grob main wheel and brake disk
does anyone know the Parker/Cleveland part number for the brake Disk
used on a Grob Twin II fixed gear which used a Cleveland caliper? Glider made about 1981.
I'm aware of the Dot 3/4 compatible O-ring used in the caliper.
Scott
Old July 17th 18, 06:48 PM posted to rec.aviation.soaring
I had ours off of the club twin II recently and took a photo of the data plate. Here is the info on ours -
Model - 40-97A
Size. - 6.00 - 6
Static rating 2500 ( I assume this is pounds!)
Wgt. 5.8. ( again, assume pounds)
On the backside of the disk there are numbers following numbers stamped into it -- 26A 233
Ours accepts the 6.00 x 6 tire.
Hope,this helps, Mark Guay
Old July 17th 18, 07:18 PM posted to rec.aviation.soaring
My bad - numbers off of the data plate refer to the wheel hub. The 26A 233 number were stamped into the bachdide of the brake disk/rotor and the only identifying information on it.
Old July 17th 18, 09:15 PM posted to rec.aviation.soaring
Scott Williams
Scott
after a couple hours on the computer, I found a listing on an archived Cleveland
application chart, seems to call out;
disk, #164-02601
caliper, #30-63A, But the O-rings have to be changed out to dot 3-4 compatible rings.
linings#066-10500
wheel, #40-97A
thanks,
Scott
Old July 18th 18, 02:14 PM posted to rec.aviation.soaring
Scott Williams
Scott
Further a Cleveland/parker part # for a chrome disc is 126-12601
Old July 20th 18, 06:36 PM posted to rec.aviation.soaring
Scott Williams
Scott
Even further,
you need an EPDM #224 o ring, for dot 3-4 compatibility, hardness shore 70
and the torque plate number might be Cleveland 075-03700
Old July 20th 18, 07:49 PM posted to rec.aviation.soaring
OK, my bad, looking to learn......what was the original hydraulic system? If mineral oil, I can see the O-ring swap, otherwise, I "believe" ANY DOT fluid works in ANY system (other than DOT 5 which REALLY SUCKS WATER OUT OF THE AIR).
So, you can run ANY DOT brake fluid in any DOT system, DOT 5 just means a lot more fluid changes.
So, DOT 1-4 and DOT 5.1 are all compatible.
Again, just asking for my edumafication as well as others (misspelling intentional).
Old July 20th 18, 08:38 PM posted to rec.aviation.soaring
On Friday, July 20, 2018 at 2:49:20 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
Are you sure about this? Sounds like you are, but DOT 5 brake
fluid is silicone based, isn't it? Hydrophobic, as I read it.
Silicone brake fluid is a favorite with some antique car owners,
since it doesn't absorb water, which rusts the interior of the
brake system. I've got it in my old cars. It has other problems,
like being harder to bleed, though.
Or I could be completely wrong again.
Jim Beckman
Old July 20th 18, 09:55 PM posted to rec.aviation.soaring
Ummmm....yes, I am very happy with my post.
Pretty much ANY DOT fluid is cross compatible EXCEPT DOT 5.
DOT 5 "will work", but it is even MORE water hungry than others. I do not believe it is a seal issue, it is water absorption issue. Thus, race cars is fine, other uses, sucks.
Now, mineral based fluids vs. DOT fluids is a different matter. Thus my question.
Oh, and to accentuate this, if you have an old system that uses DOT 1, using DOT 1-4 AND 5.1 is fine.
Yes, I made a bold statement, I will do my best to provide GOOD relevant links to prove, not just me stating it. Say, within 24hrs?
Old July 24th 18, 02:41 PM posted to rec.aviation.soaring
On Friday, July 20, 2018 at 4:55:41 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
Any progress on this question? Every source I've seen
says something like "Unlike polyethylene glycol based fluids,
Dot 5 is hydrophobic." My first reaction was that the stuff
must act like a rabid raccoon, so I had to look the word up,
but I think it means the fluid has no affinity for water.
At least, that's the way I understand it.
Jim Beckman
WTB - used Cleveland 40-78B main wheel Roy B. Soaring 1 February 19th 18 08:25 PM
hydraulic disk brake upgrade shkdriver Soaring 2 June 27th 13 05:41 PM
ASW-24 Main Wheel Removal Lauren Rezac Soaring 5 March 19th 12 04:20 PM
Tost 5“Penta disk brake wheel Mod for Duo Discus Mike I Green Soaring 0 February 6th 12 09:38 PM
Tost Disk Brake rebuild? Paul Cordell Soaring 10 April 17th 08 07:20 AM
