Dream Panel
Old July 18th 18, 02:02 AM posted to rec.aviation.soaring
2G
Default Dream Panel
As you may already know, I am ordering a new ASH31Mi. I am in the process of coming up with the panel layout and instrument selection. I would love to here from other pilots what they consider to be their dream panel (cost is not an issue).
Tom
Old July 18th 18, 03:19 AM posted to rec.aviation.soaring
Roy B.
Default Dream Panel
LX9070 computer with Remote stick, Wifi & AHRS options, KRT2 radio,Trig transponder (w/ADS-B out), 57mm Winter mechanical vario, ASI & altimeter, PowerFlarm feeding Flarmview 2. Solar panel with switching between separate LIpo batteries and ability to run any instrument on either battery and/or charge either battery. Switched gear warn system. Circuit breakers (not fuses).
Total Cost about $12,000 USD
ROY
Old July 18th 18, 03:36 AM posted to rec.aviation.soaring
Roy B.
Default Dream Panel
LX9070 computer with V9 vario, Remote stick, Wifi & AHRS options, KRT2 radio,Trig transponder (w/ADS-B out), 57mm Winter mechanical vario, ASI & altimeter, PowerFlarm feeding Flarmview 2. Solar panel with switching between separate LIpo batteries and ability to run any instrument on either battery and/or charge either battery. Switched gear warn system. Circuit breakers (not fuses), simple compass.
Total Cost about $14,000 USD
ROY
Old July 18th 18, 05:14 AM posted to rec.aviation.soaring
jfitch
Default Dream Panel
Whatever you choose (largely personal preference) I'd recommend you have Rex install and wire the panel, rather than the factory. Or do it yourself.
Old July 18th 18, 05:36 AM posted to rec.aviation.soaring
2G
Default Dream Panel
ROY
Sounds good, except I would go with the Air Avionics ACD (Air Control Display), paired with the KRT2 and VT-01 Mode S transponder (saves 1 panel cutout). And I would add the Garmin GDL 82 ADS-B. I would also use the Air Avionics altimeter (it's awesome!).
Schleicher has a thing about circuit breakers (?!).
Tom
Old July 18th 18, 06:18 AM posted to rec.aviation.soaring
jfitch
Default Dream Panel
ROY
Tom
The Air Avionics ACD is awesome, but has some limitations when used with the KRT2. It will also control a Becker. When you use the ACD-57 as a two or three purpose head, it saves panel cutouts, but you loose some display information as the display is shared. I'd probably do two, one for radio, another for altimeter and xponder control. I'm not certain the VT-01 Mode S is as yet legal in the US as an ADS-B vehicle. Sadly Trig will not let the ACD control their xpdnr.
Old July 18th 18, 08:32 AM posted to rec.aviation.soaring
krasw
Default Dream Panel
Air Glide S for inertial vario and wind
Biggest LX90x0 you can fit into panel
Powerflarm
AIR ACD altimeter (for transponder and radio)
AIR Traffic display for flarm alerts
Winter 80mm ASI, not the small one
Old July 18th 18, 10:43 AM posted to rec.aviation.soaring
Chris Rowland[_2_]
Default Dream Panel
Powerflarm
I'd look for a radio that has a double knob for setting the frequency,
outer for MHz, inner for KHz. This will be a lot easier to use than the
ones that involve a single knob and a button to change the digit to set.
There is one of the modern small radios like this, Trig maybe.
Chris
Old July 18th 18, 12:22 PM posted to rec.aviation.soaring
Default Dream Panel
Tom
Does nobody want an adsb-in receiver and traffic display?
Old July 18th 18, 12:51 PM posted to rec.aviation.soaring
Roy B.
Default Dream Panel
Space is limited and Flarmview 2 does much of traffic display.
Roy
Dream Panel [email protected] Soaring 24 September 24th 15 07:42 PM
I have a dream. A GPS/SBAS/QZSS dream ! In honour of MLK day. macpacheco Instrument Flight Rules 2 January 19th 11 12:39 AM
A Dream franck jeamourra Piloting 0 March 27th 04 07:43 PM
A dream franck jeamourra Simulators 0 March 25th 04 12:26 PM
a dream franck jeamourra Owning 0 March 25th 04 06:26 AM
