Hosin CZ Live Tracking, Live now
Old July 29th 18, 02:40 PM posted to rec.aviation.soaring
Tango Eight
Default Hosin CZ Live Tracking, Live now
18m here http://wgc2018.onglide.com/current-d...?class=18meter
Anyone know how the live tracking speeds are calculated? I see guys flying together with speeds that don't correlate with start times.
Go 70!! Go 5E!! Go XG! (CA import tariff cost you one exclamation, sorry :-))
Evan Ludeman / T8
Old July 30th 18, 10:22 AM posted to rec.aviation.soaring
Nick Hill[_3_]
Evan Ludeman / T8
As far as I know it uses the same method of calulating distance as a
scoring program. Start time, rounding TPs and current location come from
monitoring the flarm position. Given distance done and time from start
gives the speed.
The onglide software is however at the mercy of the quality of flarm
coverage so if a particular glider has poor coverage near the start or
TPs then it can miss the location at some critical times. This leads to
cases where the software doesn't register that a glider has started or
rounded a TP. Clicking on the flag for a contestant will bring up the
details and you can see what it thinks is the next target.
What is normally the case for the situation you describe is that for a
glider showing a much slower speed it has
1)Missed the correct start time i.e. the last crossing of the start line
so it is using an earlier start time from a previous crossing of the
start line whilst milling around waiting to start. or
2) Missed the fix for rounding a TP so their scoring distance for the
calculation doesn't increase leading to their speed dropping off from
that point onwards.
Remember that you can click on the different icons multiple times to
show different versions of the data. Clicking through to "Actuals" from
"Handicapped" removes a few idiosyncrasies that show early on in the
flight which is an artifact of scoring UK handicapped comps even though
in this comp there is no handicapping.. Clicking on the height icon
also changes to height above ground which can be more informative as the
they start with a ground level of ~1600ft at Hosin.
Nick Hill
TIANGONG 1 Live tracking Byker Aviation Photos 1 April 1st 18 05:01 PM
Live tracking and media done well [email protected] Soaring 0 July 2nd 17 11:08 PM
Improved live tracking for the SSA membership? Sean Fidler Soaring 83 April 22nd 17 05:31 AM
Live tracking available now (and for the next 13 days!) Sean F (F2) Soaring 2 January 7th 13 12:30 AM
UK Grand Prix Live tracking.... Nick Farrell Soaring 0 August 31st 08 06:54 PM
