Cobra Carpet
Old August 25th 04, 05:07 AM
Janus2k
Default Cobra Carpet
The glue on the carpet holds fine, the carpet is seperating into two pieces.
I am sure I am not the only one that this is happened to.
What are the recommendations for carpet?
Mark Mahan
2K
Old August 25th 04, 06:08 AM
Eric Greenwell
I just keep gluing the two pieces together, thinking eventually it will
be glue and no-foam carpet! Scraping the foam off the carpet may make it
happen sooner rather than later.
Eric Greenwell
Washington State
USA
Old August 26th 04, 04:31 AM
John Bojack
Visit your best auto upholstery shop.... they will have (should have) many
sample books with all types of appropriate carpet replacements in many
colors.
J4
"Janus2k" wrote in message
pieces.
Mark Mahan
2K
Old August 28th 04, 12:06 AM
Dick Mockler
I was about to try to reglue the large piece of carpet located in the
lid over the brackets supporting the horizontal tail. It had
progressively detached itself beginning at the front all the way back
to the bracket and was hanging down about 30" leaving the foam
attached to the lid. I discovered that the foam was backed by a sticky
paper which could be pulled off leaving no trace. I am now looking
for asource for red carpeting with a sticky backing. Dick Mockler
Old August 28th 04, 04:22 AM
Eric Greenwell
You can buy your own sticky backing and apply it to the carpet of your
choice: it's called "double sticky carpet tape", at almost any place
that sells tape. I don't know how it compares to carpet with adhesive,
or how well it holds the stuff on when the temperature gets high.
Since the foam in the original carpet is so thin and doesn't provide any
needed cushioning, I figured I'd look for suitable carpet without it,
and avoid the foam delamination problem.
Eric Greenwell
Washington State
USA
Cobra Interior Carpet Glue Brian Iten Soaring 7 August 24th 04 05:35 AM
COBRA Skin Trailer Protector - Commercial John Seaborn Soaring 0 July 20th 04 04:38 PM
Cobra Trailer Axel Replacement Carter Soaring 7 July 7th 04 02:06 PM
COBRA TALON, COBRA SPOT Allen Thomson Military Aviation 0 December 9th 03 06:44 PM
Cobra trailer fittings for different glider makes & models John W Soaring 4 September 24th 03 03:21 PM
