Advice re. Nimbus 3 OR 4Dt?
Old August 20th 18, 12:22 PM posted to rec.aviation.soaring
John McLaughlin
Default Advice re. Nimbus 3 OR 4Dt?
I'm just coming back into gliding after a long time grounded and I'm
looking to buy a glider over the winter. A two seater seems a nice idea and
the Nimbus seems to be a lot of glider for the money.
Are they in any way difficult or unpleasant to fly? I know there have been
structural failures due to loss of control.
Are they difficult or heavy to rig?
Maintenance issues? Airframe life issues?
How much would insurance typically cost - a two seater has to cost more
than a single seater?
Is winch launching unwise? Is it best to stick to a tarmac runway?
Any advice greatly appreciated, thanks.
Old August 20th 18, 01:13 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Get the 4Dt. The Nimbus 3 D, while goes well it is not nearly as nice a flyer than the 4D. The 3D has virtually no control force feedback so the stick is like a wet noodle, way worse than a bell 206.
Old August 20th 18, 03:38 PM posted to rec.aviation.soaring
Peter F[_2_]
Each point in turn...
A high performance 2-seater *is* a nice idea
There's a reason why the N3D / N4D / ASH25 sell for not a lot of money.
It's the Duo Discus, a glider that proved a high performance 2-seater could
actually be nice to fly.
Apart from straight line best L/D the Duo beats the old open ships in every
respect.
Difficult to fly - No
Unpleasant - Fairly
Loss of control - If you point a heavy, slippery glider with very long
wings straight down it's gonna get very quick very quick.
Difficult to rig no, heavy yes.
Maintenance issues, not really
Insurance for a 70,000 Euro 2-Seater will probably be less tha a 150,000
Euro single seater.
Should be no problems with winching N3D / N4D / ASH / Duo with modern
powerful winches
PF
an
Old August 20th 18, 05:21 PM posted to rec.aviation.soaring
Alex[_6_]
We had a Nimbus 3D in our club.
Rigging is fairly easy, but time consuming because of the number of parts and control connections. The inner wing weighs roughly 85kg, which is fairly heavy but it is at least not very big.
The Nimbus surely is not a beginners glider but really nothing to be afraid of. Control responsiveness is slow but effective. Stick forces are normal and not particularly heavy (as in the single-seater Nimbus 3). Landing flaps and effective spoilers allow for good approach control (better than you would expect from such a large glider).
There are some quirks: In landing flap configuration the aileron effectiveness is reduced. Especially in cross wind conditions you better land in thermalling flaps (which works absolutely fine). With full water ballast the wings loose some ground clearance. On aerotows keeping the wings level requires some attention. Also on landing I came across some club members who had consistent difficulties keeping the wings level.
Winch launching without water was never an issue and common practice at our club. But, you really don't want to drop a wing!
The series of structural failures with Nimbus are all(?) related to high altitude high speed flying. I would not worry too much unless you plan to go booming around Africa, Australia or western US.
Maintenance scales with the glider. Lot's of parts and fittings which will wear and need your attention sooner or later. Especially on used gliders the small issues have often started to pile up and keep you busy.
From a design perspective the Nimbus is pretty robust. The tailplane is the mediocre Schempp-Hirth design and the water ballast will start leaking sooner or later (as in most gliders). The outer spoiler cables tend to break or lose their adjustment. Other than that the Nimbus is just a bigger Janus/Duo Discus, which are both proven and popular designs.
Old August 20th 18, 05:59 PM posted to rec.aviation.soaring
Paul T[_4_]
parts
a=
fairly=
afraid=
normal
flap=
you
w=
effectiven=
ther=
wi=
level
requi=
who
had=
practice at
our=
al=
to go
will
gliders
th=
the=
leaking
soo=
o=
Janus/=
You might want to consider an ASH 25 instead - one of the biggest
sellers in open class.
Old August 20th 18, 09:36 PM posted to rec.aviation.soaring
Roy B.
John:
I've no experience with the N4 but the N3 is not so difficult to rig but it is very time consuming. The 10 l'hoteliere fittings (6 of which are completely "blind") take time and patience to connect and safety becuase the fuselage ones must be done by "feel" . Not a difficult glider to fly compared to other open class gliders. No issue with winch launching assuming that your winch and driver have experience with heavy gliders. Gravel & grass runways are fine assuming you have a tow plane that can accelerate smartly. Be careful in tall grass - especially if you are using a CG hook for aerotow.
All N3 & N4s with motors are extraordinarily tail heavy when ground handling. Some lifting device is helpful. Wheel braking on the Nimbus is poor. Try to get one with a trailer that allows you to keep the tip panels on in the trailer (less assembly and taping).
Many N3 owners (including me) changed 2 things: 1) Disconnected the bungees that run to the outer panel spoilerons (which were useless anyway) as this reduced the aileron control force without adverse impact on control, and 2) ignored the directive to completely fill the outer panels with water before filling/using the inner panels. Having about 40% water in the outer panels and 60% in the inner panels helped the roll rate significantly.
I agree with the others that the ASH-25 is a nice glider also. I think it handles a bit better than the Nimbus and has the flap handle up on the gunnel where it belongs. I did not like having to stare at the floor to find what flap position I was in (which you must do with the Nimbus). Both are well supported by their factories.
Good luck.
ROY
Old August 20th 18, 10:48 PM posted to rec.aviation.soaring
Craig Funston[_3_]
Hi John,
It wasn't clear whether you're looking only at the 3D and 4D or whether you're also considering single place Nimbus options. I've had my N3 for 18 years and loved my time flying it. It's hard to beat the performance / $. I just put mine up on W&W because it's being replaced by a self-launcher.
https://wingsandwheels.com/class/classified.php?id=3052
You're welcome to pm me if you want more info on rigging, flying, etc. I've got time in the N3, N4 and N4D and am happy to share what I've experienced..
Cheers,
Craig
Old August 22nd 18, 12:50 AM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Hi John
I currently own a Nimbus 3D and a Ventus a. I swap between the 2 without any problems and the Nimbus doesn't feel ponderous at all to me
I've some time in a Duo X and I'd describe the 3D as being like a slightly sluggish Duo to roll especially if you are flying it too slow, then it resembles an out of control barge :-) . Appropriate speed is the key. Both flight manuals quote 4.4 seconds for the 45 to 45 turn reversal at their respective MAUW with the Nimbus in +2 thermal flap at 60kts and the Duo 4kts slower. I have no hesitation in doing reversals while thermalling if I think it will centre me quicker. No problems with either aerotow or winching and I don't even mind a wing down take-off from grass on aerotow if no wing runner is available.
Unlike some I fly with the tip spoilers connected and as they only deploy (if properly adjusted) when nearing full aileron travel there is no drag penalty when flying 'clean'. They help a lot with rapid maneuvering enabling you to put the glider where you want it quickly and be back 'clean' again. The biggest hinderance in flying big wings that my fellow pilot ride alongs display is a lack of willingness to use full controls as necessary.
I've had a few passengers who have ASH 25 time fly with me and they all say the Nimbus is more responsive and quicker handling, but I suspect that relates more to lack of appropriate speed as the one time I flew an ASH with Terry Delore in NZ I thought it was fine and was looking to buy one before I settled on the Nimbus
I solo rig the Nimbus in c.40- 45 minutes and it's the endless taping that's the biggest drag and de-rig in 30. I regularly land the Nimbus shorter than the club Duo and twice have outlanded the Nimbus in c.140yd (1st and last landouts to date with another 2 or 3 in there)
Any way that's my opinion from owning a 3D and it's only an opinion. Some people like big wings and some don't.
Good luck and welcome back to soaring
:-) Colin
Old August 22nd 18, 09:03 AM posted to rec.aviation.soaring
Peter Purdie[_3_]
I have had a little time in Nimbus 3 (2 aircraft, from opposite ends
of the production series), Nimbus 4, Nimbus 3DT, Nimbus 3DM and
Nimbus 4DM, and also many more hours in ASH25. A little time
may be a plus, since in my experience, you can get used to anything
and think it is better than acceptable.
In my personal opinion, ease of handling is important, it leaves time
to think about the important things like where to go next - if your
concentration is on maximising the climb while flying an unwieldy
lump, then that takes away from time better spent.
Having said which, I would avoid a very early Nimbus 3 and
especially the earliest 3Ds before they increased the tail area and
changed control relationships. Later ones are nicer. The 4 series
are a lot nicer to fly, and the single seat 4 feels like a much smaller
glider - a pleasure to fly.
The ASH25 is quite different, but you get used to it quite quickly.
I haven't done a full spin in any of the above, and wouldn't want to,
that's test pilot stuff; I have approached divergence in all of them
and they all gave me sufficient warning.
I say again, all the above is personal opinion.
At 23:50 21 August 2018, Ventus_a wrote:
I'm
nice ide
an
hav
bee
cost more
Hi Joh
to m
th
flap a
reversal
wit
take-of
quickly an
tha
they al
suspec
flew a
to bu
Nimbu
c.140y
opinion
:-) Coli
Ventus_a
Old August 22nd 18, 04:22 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I'm
nice ide
an
hav
bee
cost more
Hi Joh
to m
th
flap a
reversal
wit
take-of
quickly an
tha
they al
suspec
flew a
to bu
Nimbu
c.140y
opinion
:-) Coli
Ventus_a
Just a note on these big birds, it can pay to check the rigging, especially if it is new to you. I flew a Nimbus 4 that was severely mis-rigged and flew like it. A few hours in the shop, well better part of a day, a hot day, rigged correctly it flew like a beauty.
Nimbus 2/2B thermalrider Soaring 1 August 23rd 09 02:12 AM
FS: Nimbus 3-25.5 JS Soaring 0 February 19th 08 07:49 PM
FS Nimbus 3 Roy Bourgeois Soaring 0 December 26th 07 07:47 PM
F.S. Nimbus 3 [email protected] Soaring 2 July 12th 06 02:35 PM
FS: Nimbus 4 Dirk Elber Soaring 0 November 10th 04 09:59 PM
