I’m looking for a cross county glider. The Ventus C comes with 17.5 and 15 winglets. It also has factory tips. The LS6 has low hours and the wings and horizontal stab was refinished and painted. The fuselage is in good condition and original. Both have Cobra trailers and the Ventus’s trailer is in better condition. The other is road worthy. Which one?
My humble opinion: They're both fine sailplanes, and Cobra trailers are pretty darn good even when not in the greatest shape. The LS6 is probably the sweeter flying glider. But if it is an earlier one without auto-connect controls, I'd let the trailer be the deciding factor and go with the Ventus.
--Bob K. |
Hi there,
having owned both, I'd always go with the LS6. The Ventus C handling is not bad, but it needs constant attention when circling in narrow thermals, because it's stability isn't very good (but better than the B-version). This is easier with an LS6. Also personally I prefer LS cockpits because of the nice seat back and headrest which are more comfortable, if you fit in. Then you have waterbags instead of integral tanks, which are easier to service in case of leakage. If it's an LS6-c, it also has automatic connections of the controls, so no difference there. You probably wouldn't prefer an LS6-a or -b over an Ventus-c, because it has only 15m of span. About the trailer, if it's not in a total devastating state, it should be ok. You can repair it during winter or get a better one. I'd base my decision more on the glider, it's handling, state and comfort. Regards Stefan |
Le mercredi 29 août 2018 15:22:55 UTC+2, a écritÂ*:
Hi there, having owned both, I'd always go with the LS6. The Ventus C handling is not bad, but it needs constant attention when circling in narrow thermals, because it's stability isn't very good (but better than the B-version). This is easier with an LS6. Also personally I prefer LS cockpits because of the nice seat back and headrest which are more comfortable, if you fit in. Then you have waterbags instead of integral tanks, which are easier to service in case of leakage. If it's an LS6-c, it also has automatic connections of the controls, so no difference there. You probably wouldn't prefer an LS6-a or -b over an Ventus-c, because it has only 15m of span. About the trailer, if it's not in a total devastating state, it should be ok. You can repair it during winter or get a better one. I'd base my decision more on the glider, it's handling, state and comfort. Regards Stefan I have about 1400 h in my Ventus cM (17.6 m) and have flown extensively "against" a LS6-18W. The handling of the Ventus is very nice and docile; you can take off your hands during thermalling. All pilots of LS6-18W's consistently tell me what a pleasure the glider is to fly - I suppose that there is some truth there ;-) Performance-wise, the LS6 was climbing better than me, but he was at 36 kg/m2 while I was at 44 kg/m2. On the L/D, it seems to me that the LS6 has 1-2 points more (the Ventus is at 47). |
Art (LS6) math (Ventus C)
Main factor, pilot size, LS6 has a smaller cockpit, goes a bit better. If you fit, LS all the way. But you gotta pay the LS tax, thanks to DG. |
The 'LS' (maintenance contract with DG) tax is not really necessary. I own a LS6a and if you don't have a big repair or you don't need special components you don't have to contact DG... Lukas
On Monday, September 16, 2019 at 3:03:59 PM UTC-5, wrote:
The 'LS' (maintenance contract with DG) tax is not really necessary. I own a LS6a and if you don't have a big repair or you don't need special components you don't have to contact DG... Lukas And if $250 per year is going to "keep you from buying a sailplane", you weren't really going to buy a sailplane in the first place, now were you? Steve Leonard LS6a repair project serial 6037 N511M |
On Tuesday, August 28, 2018 at 11:35:38 AM UTC-7, Marshall Woodford wrote:
I’m looking for a cross county glider. The Ventus C comes with 17.5 and 15 winglets. It also has factory tips. The LS6 has low hours and the wings and horizontal stab was refinished and painted. The fuselage is in good condition and original. Both have Cobra trailers and the Ventus’s trailer is in better condition. The other is road worthy. Which one? |
I've owned both a Ventus C and a LS-6 (my current ship). Personally, it's a no-brainer. The LS-6 is a joy to fly, and the Ventus required constant attention, and was always ready to blind side me.
Sailors have an expression to describe a boat that has an easy motion, responds to the tiller and leaves one refreshed (not exhausted) after a long ocean passage: "Sea Kindly." Well, the LS-6 is "Air Kindly." It holds a 45 degree bank without difficulty, has an easy motion, and responds quickly and positively to control inputs. Plus, it has a good turn of speed in negative flaps, and climbs easily. I would have no hesitation in recommending the LS-6. Matt Herron |
Thread Drift warning
So I've got a LS ship I've never paid the "Tax" So how does this work if I NEED a LS part? Do they hold me hostage for the many years I've owned the ship before they will sell me said Part? Or do I just join up then? Can I just pay for the one year I need a part? |
Ventus 3? | Peter F[_2_] | Soaring | 26 | December 4th 15 11:03 PM |
FS: Ventus C | KO | Soaring | 0 | January 20th 06 08:43 PM |
Ventus C 17.6 | John Shelton | Soaring | 0 | January 17th 05 05:48 PM |
Ventus C 17.6 | John Shelton | Soaring | 0 | November 18th 04 08:39 PM |
FS Ventus C 17.6 | John Shelton | Soaring | 0 | November 15th 04 09:10 PM |
