Becker AR4201 friction between frequency adjustment knobs
Old September 8th 18, 01:39 AM posted to rec.aviation.soaring
Default Becker AR4201 friction between frequency adjustment knobs
I have such a radio, and when you turn one of those concentric knobs, the other one turns too, unless you hold it firmly. Thus it takes two hands to turn only one knob. How can I adjust it work as intended?
Old September 8th 18, 01:47 AM posted to rec.aviation.soaring
JS[_5_]
On most dual concentric knobs, you take off the cap of the smaller (closer) knob and loosen the screw under the cap. Then pull the knob out a bit and tighten the screw. Check it for friction, make sure it's really tight and put the cap back on.
Old September 8th 18, 02:07 AM posted to rec.aviation.soaring
Thanks Jim. That did it, and was easy. I had no idea that cap comes off. Was looking for screws on the sides, and there are none.
Becker AR4201 John Williams Soaring 3 August 12th 17 03:09 PM
Becker AR4201 Robin Birch[_2_] Soaring 0 April 21st 14 06:22 PM
Becker AR4201 Robin Birch[_2_] Soaring 0 April 21st 14 05:11 PM
BECKER AR4201 guts Soaring 1 April 23rd 12 08:50 PM
VHF Becker AR4201 Philippe Home Built 2 July 9th 04 08:30 PM
