Flying Gliders in Europe: Medical Requirements
Old September 8th 18, 05:52 PM posted to rec.aviation.soaring
Default Flying Gliders in Europe: Medical Requirements
I'm trying to put together a trip to the LAK factory in Lithuania to test fly the new MiniLAK FES, a 16.5 meter self launch that I may decide to purchase.
The folks at LAK are onboard, but the civil aviation authority in Lithuania is raising bureaucratic barriers to my flying there. They've accepted my FAA license, passport, flight logs, etc. but have balked at a letter from my physician stating that I am fit to fly gliders. They want her to sign a letter stating that my health "corresponds to the requirements of Annex 1 of the Chicago Convention."
Translation: The ICAO convention in Chicago in 1944 set standards for international air travel, including pilot medical requirements, which are detailed in ICAO Document 8984, Manual of Civil Aviation Medicine. Unfortunately, the link on the ICAO web site to this manual doesn't work, and I can't find any other way to obtain that document, so I can't even inform my doctor about what she needs to know to write that letter.
Does anyone have experience obtaining certification to fly gliders in Europe? I've had no problem flying in New Zealand, but Lithuania seems to be a special case.
Matt Herron (Sr)
Old September 8th 18, 06:30 PM posted to rec.aviation.soaring
You will need to bring the original Class II medical certificate with you. You should forward a copy before you leave on your trip and demand a response from them that indeed it is acceptable. I've flown in France many times including this year and that is what was required and accepted.
Matt Herron (Sr)
Old September 8th 18, 06:49 PM posted to rec.aviation.soaring
Tom BravoMike
Matt Herron (Sr)
I believe it's not about Lithuania, it's the European Union. Once you are approved to fly with your FAA license in Lithuania, you can fly in most, if not all, EU countries, if I'm not mistaken. Years ago Class III medical was good enough, now it results it has to be Class II. Generally, glider pilots are not exempted from medicals in Europe, like they are here in US.
Old September 8th 18, 10:34 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
Matt Herron (Sr)
1st result from a Google search
http://web.shgm.gov.tr/documents/siv...x%201-ed11.pdf
:-) Colin
Old September 9th 18, 12:25 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Matt Herron (Sr)
Went to Germany last year to fly a D registered glider. A Class II medical was sufficient to satisfy the ICAO requirements. Have fun in Lithuania!
Craig
7Q
Old September 9th 18, 12:27 AM posted to rec.aviation.soaring
Dan Marotta
Why not see an AME and get a Medical Certificate Class III?
Matt Herron (Sr)
Dan, 5J
Old September 9th 18, 12:30 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Matt Herron (Sr)
Dan, 5J
Class III doesn't meet ICAO requirements
Old September 9th 18, 02:16 AM posted to rec.aviation.soaring
John Huthmaker
Matt Herron (Sr)
Dan, 5J
Depending on the pilot, there may be very good reasons not to apply for a new medical. You can only use BasicMed if you've never been declined for another medical certificate. If your borderline that you may not get one, you're better off never applying for one again.
Old September 9th 18, 09:16 AM posted to rec.aviation.soaring
I have been flying in Europe for some time. In the EU, the standard is the FAA Class 2 Medical Certificate. They will not honor a Class 3 or a clearance letter.
An alternative in France is to obtain a medical examination from a flight physician in France. On my second trip to France my Class 3 Medical was refused but at St. Auban they set me up with a flight physical the next day.
Old September 10th 18, 09:36 AM posted to rec.aviation.soaring
Matt Herron (Sr)
That's only the case if you are flying a glider registered in the EU. Pilots with FAA licenses flying N-registered gliders do not have to comply with EASA pilot certification and medical rules.
Medical requirements ? Nigel Henry Soaring 3 March 16th 16 11:44 PM
UK medical requirements for US glider pilots... Marc Ramsey Soaring 8 August 28th 06 06:44 PM
UK medical requirements... Marc Ramsey Soaring 0 August 16th 06 04:55 AM
New class 2 medical requirements Robert M. Gary Piloting 2 August 23rd 04 10:41 PM
Overly restrictive business flying requirements. Wily Wapiti Piloting 53 August 25th 03 11:34 PM
