vinyl wrap
Old October 4th 18, 01:59 AM posted to rec.aviation.soaring
Default vinyl wrap
Greetings all, I was wondering if anyone here has any information or experience with vinyl wraps for wings, control surfaces, fuselage on sailplanes, It seems that this product would be pretty easy to use on ailerons, elevators and rudders and would be insignificant weight gains. Iknow that it is used in aviation. I think that the biggest issue may be static electricity and any drag resulting from dust adhered to surface of the wing due to static electricity
Old October 4th 18, 02:22 AM posted to rec.aviation.soaring
Andrzej Kobus
Default vinyl wrap
I would not even think about putting any wrap on control surfaces. The weight is not insignificant for control surfaces.
Old October 4th 18, 03:28 AM posted to rec.aviation.soaring
Randy Teel
Default vinyl wrap
I have seen an entire Twin Astir wrap and it looks beautiful. I have also the rudder on an ASW27 wrapped. Send me an email and I will forward the information/contact to you.
Randy
Old October 4th 18, 05:50 AM posted to rec.aviation.soaring
AS
Default vinyl wrap
Randy
Here is a nice video showing how it is done on a glider for decorative purposes. Pretty neat!
https://www.youtube.com/watch?v=jVSxEuOZMFE
Uli
'AS'
Old October 4th 18, 08:33 AM posted to rec.aviation.soaring
Fraser Wilson[_2_]
Default vinyl wrap
I considered doing this but one of the problems I came across is
the 3M 1080 film, probably the best on the market, is only
available in a 1.8m width, which is not wide enough to do a
seamless job on my wing (single seat 15m). I understand it
shrinks with age so any seams will tend to open. So I went for
paint.
I’ve since found another gloss white film manufacturer offering a
2.5m width, but it’s service durability is unproven, unlike 1080.
I would be interested in any pictures of the twin Astir, which film
they used, how they’ve done seams and how the film is standing
up to the test of time.
Fraser
wrote=
information or
ex=
sailplan=
ailerons,
ele=
Iknow that it
i=
electricit=
wing due to
st=
atic electricity
=20
have
also=
forward the
i=
=20
Randy
decorative
purp=
oses. Pretty neat!
https://www.youtube.com/watch?v=3DjVSxEuOZMFE
Uli
'AS'
Old October 4th 18, 02:52 PM posted to rec.aviation.soaring
Default vinyl wrap
Concordia used film finish on control surfaces for weight saving.
That said just putting over old cracked gelcoat would be a poor decision.
UH
Old October 4th 18, 04:50 PM posted to rec.aviation.soaring
Fraser Wilson[_2_]
Default vinyl wrap
available in a 1.5 m (correction from previous) width, which is
paint.
standing
Fraser
wrote=
information or
ex=
on
sailplan=
ailerons,
ele=
Iknow that it
i=
electricit=
wing due to
st=
atic electricity
=20
have
also=
will
forward the
i=
=20
Randy
decorative
purp=
oses. Pretty neat!
Uli
'AS'
Old October 4th 18, 06:19 PM posted to rec.aviation.soaring
Default vinyl wrap
Monokote or similar?
Old October 6th 18, 12:25 AM posted to rec.aviation.soaring
Default vinyl wrap
UH
Why? Not challenging what you say, UH, just want to understand what the issues would be. I can guess some, but I would love to hear yours, much more of an experience base than mine....
Cheers,
J6
Old October 6th 18, 12:58 AM posted to rec.aviation.soaring
Default vinyl wrap
UH
Cheers,
J6
1- Unless enough of the existing finish is removed, there likely will be mass balance issues.
2- If failing finish is not removed, the failure of the finish will continue. It is cracking because it is old and brittle and shrinking.
3- Crappy under surface will almost certainly show through unless sanded smooth and flat.
"There has to be an easier way".
UH
Vinyl Numbers [email protected] Soaring 10 June 20th 18 12:03 AM
Applying Vinyl Contest numbers..... Gary Adams Soaring 0 May 11th 12 11:13 PM
Removing vinyl letters Gary[_5_] Soaring 7 December 31st 11 07:10 PM
vinyl trim source Brad[_2_] Soaring 3 March 23rd 10 06:02 AM
Plastic/Vinyl letters Mel Dawson Soaring 23 February 19th 06 12:46 AM
