New $500 FAA ADS-B Rebate ... some motorgliders/sustainers qualify
Old October 12th 18, 06:27 PM posted to rec.aviation.soaring
Darryl Ramm
Default New $500 FAA ADS-B Rebate ... some motorgliders/sustainers qualify
It's back.... https://www.faa.gov/nextgen/equipadsb/rebate
Hopefully may be time for some folks doing ADS-B Out installs over this winter break to get a rebate. Only applies to 2020 Complaint installs (so not TABS/SIL=1).
And the rules make clear...
Type Aircraft = ‘Fixed wing single engine’ or ‘Glider’; AND
Type Engine = ‘Reciprocating’ OR ‘4 Cycle’ OR ‘2 Cycle’
So only applies to non-jet sustainers and motorgliders.
I'm mostly curious how many folks are willing to deal with all the extra effort for $500.
It's of course a silly way of doing this, I would have much preferred to see a program that targeted all aircraft including gliders, maybe targeting those based or flown around busy traffic areas.
Old October 12th 18, 07:04 PM posted to rec.aviation.soaring
JS[_5_]
To keep up the cheapskate glider pilot stereotype, I'm installing a BMW 4-stroke self-launch kit in the 29 so I can get a $500 rebate on ADS-B.
Old October 12th 18, 07:07 PM posted to rec.aviation.soaring
Darryl Ramm
OK well I goofed there. It applies to non-jet and non-electric motorgliders and sustainers.
Sorry did not mean to leave off the electric. Thanks to Dave Nadler for the correction.
Darryl
Old October 12th 18, 07:32 PM posted to rec.aviation.soaring
Interesting update, I believe the old rebate excluded any aircraft with "no electrical system (gliders, Cubs, etc.)".
So, no gliders were included, maybe even motorgliders/self launchers/sustainers.
Old October 12th 18, 08:01 PM posted to rec.aviation.soaring
Dan Marotta
Default New $500 FAA ADS-B Rebate ... some motorgliders/sustainersqualify
Well...Â* My Stemme has an electrical system.Â* I'm taking a look.
My concern is about getting a Supplemental Type Certificate (STC) for
the installation.Â* My past research, surely out of date by now, named a
single avionics shop as Trig's representative for the TT22/TN70
combination.Â* When I last looked there was no mention of the Stemme on
their vast list of acceptable aircraft.Â* Maybe that's now changed or
maybe my mechanic can do a simple field install. We'll see...
Dan, 5J
Old October 12th 18, 08:42 PM posted to rec.aviation.soaring
Darryl Ramm
Dan
As mentioned in a recent email. Any of the glider Trig resellers should be able to get you/your A&P the required STC for the TN70+TT22 for install with your or any other glider. Wings and Wheels and I and others worked with Pereguine (the STC holder) and Trig to make sure that STC would be available to glider installers. Go through your favorite Trig glider dealers and if you have problems with the STC let me know. Pereguine are great folks.
Be careful: If you walk into a random GA avionics shop who is not a Trig approved installer that may (correctly) tell you they cannot get that STC.
Old October 12th 18, 08:49 PM posted to rec.aviation.soaring
Dan Marotta
Thanks Darryl,
I just got back from the Peregrine website and found no reference to
Stemme in their AML.Â* Since I bought my TT22 from Paul Remde, I've
contacted him for help.Â* I also emailed Peregrine.
Dan
On 10/12/2018 1:42 PM, Darryl Ramm wrote:
Dan
Dan, 5J
Old October 12th 18, 09:18 PM posted to rec.aviation.soaring
Darryl Ramm
Uh let’s kill that one. I have mentioned this lots before but it is confusing. Your Stemme does *not* need to be on the STC AML. Your A&P should not be using this STC as basis for a major modification. They sould only using this as justification for the pairing of the TT22 and TN70. Your installer should refer to FAA AFS-360-2017-1, INSTALLATION OF ADS-B OUT EQUIPMENT. And do just what is required there, and no more. https://www.faa.gov/nextgen/equipads...r(9-25-17).pdf
Please have your A&P/avionics shop talk to me if they have questions about this.
Darryl
Old October 13th 18, 06:16 AM posted to rec.aviation.soaring
2G
Darryl
It also doesn't apply to rotary-powered aircraft like Schleichers. It is easier to say that it DOES apply to piston-powered aircraft, so Solo equipped MGs are covered. Also, the aircraft must have been registered prior to 1/1/16.
Tom
Old October 13th 18, 06:55 AM posted to rec.aviation.soaring
Darryl Ramm
Yes! But wait... it's even sillier.... it depends. Some Schleicher motorglider engines are listed as "rotary" and some as "reciprocating", depends on what engine manufacturer they are keyed in under, for basically the identical engine. I should have looked more carefully, I had checked "Mid-West" and that returned "reciprocating".
It would have been great if the SSA was looking at this rebate program.
I am going to try to ask folks in the FAA about it.
There is interesting stuff in the FAA registration database. Like what is going on he https://registry.faa.gov/aircraftinq...umbertxt=794FM :-0
Darryl
Darryl
Tom
Would it qualify for hazardous duty pay? Byker Aviation Photos 0 September 1st 15 03:42 AM
Sustainers and Self-Launchers- How often and for how long do you runyour motors (after launch)? son_of_flubber Soaring 5 April 21st 14 06:56 PM
FAR 61.58 regarding HpH 304SJ,Jonker JS1-CJT, et al jet sustainers [email protected] Soaring 2 May 23rd 13 04:52 PM
73 old planes that qualify for Light-sport [email protected] Piloting 1 September 14th 10 12:35 AM
Don't Know If It Would Qualify... Jay Beckman Home Built 4 March 30th 04 07:17 AM
