ASG32MI water ballast
Old October 15th 18, 08:46 AM posted to rec.aviation.soaring
Fassin Pierre
Default ASG32MI water ballast
Hello, I am looking for some help concerning the water ballast in the TAIL of the ASG32. Don't know what happens but since some time now, it takes 45 minutes to fill or empty the 5 liters in the tail. It used to be 3 or 4 minutes... So, obviously, something blocks... I verified the cabling under the front seat, and all works perfectly, buy all I mean the opening and closing. So it is somewhere in the tail section. There is either some dirt or something that blocks. I wonder if it is useful to remove the rudder to get access to the mechanism. Somebody has experience with this?
Thanks a lot
Pierre
Old October 15th 18, 01:42 PM posted to rec.aviation.soaring
Thanks a lot
Pierre
Check the tank vent(s) for blockage.
UH
Old October 15th 18, 01:49 PM posted to rec.aviation.soaring
Roy B.
Pier
I had this problem with my '29 but not as bad as your situation. I figured that something was blocking the tail vent tube. I used a device called a "baby aspirator" (used to gently clean snot from a baby's nose) to work some warm water backward through the vent in the side of the fin. The problem got better - but never back to the way it was when new.
ROY
Old October 15th 18, 05:35 PM posted to rec.aviation.soaring
JS[_5_]
On Monday, October 15, 2018 at 5:49:16 AM UTC-7, Roy B. wrote:
Pier
ROY
Think we'll be working on my 29 tail tank this winter, am hoping to install a better way of filling (from the top, what a concept) instead of through the dump valve.
Similaraly bypassed the factory tail tank fill method on LS6 #46. Removing the horizontal stab to fill was foolish.
Film at 11.
Old October 15th 18, 05:41 PM posted to rec.aviation.soaring
Roy B.
Jonkers uses a modified garden sprayer that fills through the vent hole. You pump it and it squirts into the hole through a reduced hose. It works OK but it's another piece of stuff bouncing around in your trailer.
ROY
Old October 15th 18, 05:54 PM posted to rec.aviation.soaring
JS[_5_]
ROY
Correct.
Did that while flying JS1C.
There is also a second tank for C/G adjustment which is a fantastic idea.
With the supply on the HS it'll gravity feed like a Schempp-Hirth or the aforementioned LS6 (also ASW20) mod. Can be done while filling the wings, as the dump valve is closed.
Old October 15th 18, 06:04 PM posted to rec.aviation.soaring
Roy B.
Jim:
The biggest advantage to gravity feed via the vent is that you can fill the tail after filling the wings. With fill through the dump valve you can't do that. Agreed that the dual tank in the JS-1 was a good idea.
ROY
Old October 15th 18, 07:11 PM posted to rec.aviation.soaring
Had the same with my 32. The cable that operates the valve got streched, so the valve wouldnt open fully. So I put more pressure on the filling port, until the silicon tube between the valve and the tail tank came loose. So you need to check the connecting tube, and adjust the cable operating the valve
Old October 16th 18, 12:18 PM posted to rec.aviation.soaring
Assuming that it's the same mechanism as in the 29: In the ASW-27 yahoo group, there are some photos of the valve outside of the plane. Maybe that helps to understand whats going on.
Old October 17th 18, 10:07 AM posted to rec.aviation.soaring
Rhubarb[_2_]
my ASG29 fin ballast valve cable streched over the winter when I left it in "Open". The result was that it would start dumping slowly on the grid (as the day got hotter and cable got even longer?)
To fix it you have to unsolder the fin cable from the main wings cable. A mini adjuster (eg like on yacht mast stays) would have made life much easier
water ballast 6PK Soaring 16 July 15th 15 01:43 PM
Water Ballast Tripod [email protected] Soaring 3 July 31st 12 05:43 PM
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
astir cs-77 water ballast pete83 Soaring 4 May 27th 04 05:21 AM
