Which Soaring weather service subscription is best?
Old November 13th 18, 04:46 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Default Which Soaring weather service subscription is best?
I think I'm going to subscribe to a Soaring weather forecast service.
Which ones are great and easy to use without alot of prior knowledge?
Skysight?
Old November 13th 18, 04:55 PM posted to rec.aviation.soaring
JS[_5_]
Skysight?
I prefer SkySight to XC Skies of Top Meteo.
Top Meteo isn't as easily readable as the others. A sea of numbers with rivers as the background map?
SkySight is owned by a true enthusiast. Responsive to user suggestions.
The other... In my experience has VERY poor response to customers.
Old November 13th 18, 04:58 PM posted to rec.aviation.soaring
Skysight?
We (SkySight) have a free trial, so I encourage you to give it a try and see what you think.
If you get stuck there's a tutorial video at https://www.youtube.com/watch?v=8RIN0086LzY
Regards,
Matthew
Old November 13th 18, 05:02 PM posted to rec.aviation.soaring
JS[_5_]
Skysight?
Regards,
Matthew
Matthew:
Thanks for an example of response time.
Old November 14th 18, 04:43 AM posted to rec.aviation.soaring
Branko Stojkovic
Regards,
Matthew
Hi Matthew,
Do you have any plans for adding Western Canada (BC and Alberta) to the regions your forecasts cover?
Branko XYU
Old November 14th 18, 10:32 AM posted to rec.aviation.soaring
Regards,
Matthew
Hi Matthew,
Branko XYU
We cover most of Alberta already, if there is a high enough density of pilots in BC to support forecasting operations there, we will extend to it.
Old November 14th 18, 04:16 PM posted to rec.aviation.soaring
Branko Stojkovic
There are around 40 pilots in BC, out of which around 10 may be interested in subscribing (my guess).
Old November 14th 18, 07:38 PM posted to rec.aviation.soaring
MNLou
Regarding which is better -
Why not both? That's what I'm doing. I like them both and the additional cost is about 2 tows a year.
I haven't found any trend where one is consistently better than the other and I do like the different options between the two.
I find they can be somewhat different 3 days out but tend to converge closer in to the day of flight.
Kudos to Matthew for being very responsive 100% of the time!
Lou
Old November 13th 18, 05:53 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
OK
I'm gonna give that Skysight a go!
Old November 17th 18, 07:58 AM posted to rec.aviation.soaring
andrzop
W dniu wtorek, 13 listopada 2018 17:46:24 UTC+1 użytkownik Nick Kennedy napisał:
Skysight?
The best is FCST24, especially for mountains and wave flying.
Second SkySight if you don't have FCST24 or Top Meteo if you have it.
it's good to use 2 different models sources to compare certainty of the forecast. SkySight and FCST24 I think they have the same weather data source.
Steve's Soaring Service BDS[_2_] Soaring 2 June 23rd 08 03:14 PM
GPS weather subscription? tom pettit Piloting 3 February 16th 07 03:22 PM
Best US Soaring Weather [email protected] Soaring 21 May 9th 06 06:13 PM
WSI weather service Jim Burns Piloting 4 July 21st 05 03:16 PM
New Self-Service Soaring Ad Site TraderGuy Soaring 15 March 4th 04 09:46 PM
