Glider Simulator Training at the USAFA
Old November 14th 18, 10:05 PM posted to rec.aviation.soaring
Default Glider Simulator Training at the USAFA
In the summer of 2018, the United States Air Force Academy began using Mach 0.1 Simulated Glider Cockpits as part of their "Glider Airmanship" course. The data collected from the course shows that the solo rate for students who completed the course in 2018 was more than double the solo rate of the previous two years.
To see a full article about the program, send us an email to and we will email you a copy.
Old November 15th 18, 02:30 AM posted to rec.aviation.soaring
Giaco
How does this differ from the simulators that they have been using since 2008? They have had condor hooked up to all the controls on a wrecked L-23 fuselage with head tracking for a number of years, and I thought they implemented simulator time as part of the curriculum as far back as 2009-2010...
Old November 15th 18, 03:30 AM posted to rec.aviation.soaring
I am not sure what you are referring to. The people I worked with didn't mention any other use of glider sims at the Air Force Academy other than some brief experimentation with Condor using a table top joystick. In this program, each of the 340 students in the glider course trained for several hours on one of eight Mach 0.1 Simulated Glider Cockpits, using custom lesson scenarios I developed for Condor 2.
- Russell Holtz
Old November 15th 18, 01:19 PM posted to rec.aviation.soaring
In my experience with the USAFA glider program, both as a cadet instructor and later as the officer-in-charge of the advanced soaring program, the vast majority of students achieved the end goal of the Airmanship 451 program, which was to solo. That act completed the course.
Has the AM 451 curriculum changed whereby most students now do *not* solo (which would have to be the case to "more than double the solo rate")?
Old November 15th 18, 01:25 PM posted to rec.aviation.soaring
This was for AM 251.
Old November 15th 18, 08:26 PM posted to rec.aviation.soaring
The sims were used in the AM 251 course, the "Into to Soaring" course given during the summer for 340 students, not the AM 451 which is used to train the instructors. The AM 451 course only has about 60 students, and yes, most of those have already soloed, or come close, in AM 251.
Old November 16th 18, 12:59 AM posted to rec.aviation.soaring
One obvious difference is that a simulator based on a wrecked glider fuselage is a one-off project -- it's not scalable. A commercially available simulator rig that seemlessly integrates with the most popular glider simulator is something worth considering by glider clubs. I suggest requesting the article mentioned in the original post.
Old November 16th 18, 01:00 AM posted to rec.aviation.soaring
Back when the rains came & the earth cooled:
400-series academic courses were associated with a cadet's freshman ("4-degree") year.
AM-451 was typically taken the summer break before a cadet's began his sophomore year.
The USAF ACADEMY SOARING PROGRAM SYLLABUS OF INSTRUCTION FOR AIRMANSHIP 451, BASIC COURSE GLIDER, Dated APRIL 1980, states, "This syllabus outlines...the training required...to solo a glider."
As for the 1980s through the 1990s--The vast majority of BASIC COURSE GLIDER students achieved solo. It was rare not to solo.
When did not soloing become the norm (hence the modern-day possibility to double the BASIC COURSE GLIDER solo rate)?
Old November 16th 18, 01:28 AM posted to rec.aviation.soaring
This is true. Back when the USAFA was training in 2-32s, the solo rate was much higher. They are now using a "club" version of the DG-1000, and the solo rate was around 40%. But by adding simulator training there were able to get that up to 89%.
-Russell Holtz
Old November 16th 18, 01:29 AM posted to rec.aviation.soaring
This is true. Back when the USAFA was training in 2-33s, the solo rate was much higher. They are now using a "club" version of the DG-1000, and the solo rate has been around 40%. By adding simulator training there were able to get that up to 89%.
-Russell Holtz
Soaring Simulator Training and Competiton RN Soaring 11 February 5th 10 04:49 AM
Google Earth Glider on Tow USAFA Shawn[_3_] Soaring 8 July 24th 07 08:40 PM
Flight simulator training. Richard Piloting 2 April 2nd 06 05:11 PM
R22 training software or simulator?? EGWW Rotorcraft 14 October 26th 03 01:36 AM
Laser simulator provides weapons training Otis Willie Military Aviation 0 August 28th 03 09:58 PM
