anyone have a Cad file of a nimbus 2 panel
Old December 2nd 18, 06:36 AM posted to rec.aviation.soaring
Default anyone have a Cad file of a nimbus 2 panel
Fitting new instruments into a Nimbus 2 panel,
does anyone have a cad file of the panel or a
site where I can access one.
Old December 3rd 18, 03:41 AM posted to rec.aviation.soaring
Mike C
If the Nimbus 2 has the same panel as the Mini Nimbus, there are several files on the Mini Nimbus Yahoo group.
Old December 3rd 18, 07:39 PM posted to rec.aviation.soaring
Surge
I have a CAD drawing I made for my Nimbus 2 BUT ...
1. It's not identical to the original due it being a copy and tweak of another copy.
2. My panel mountings are not original which changes the shape where it meets the cockpit sides.
3. The panel has bends on the bottom which need to be done accurately for the mounting foot to fit (which is a seperate piece I riveted on).
If it's only for laying out instruments it should be good enough.
I think the Cirrus panel is almost identical so that may also be an option.
If you want to be certain things will fit why not just measure your current panel and redraw it in a CAD application? It shouldn't take more than an afternoon.
Nimbus 3 Instrument panel John Orton[_4_] Soaring 2 April 22nd 16 06:11 AM
FS: Nimbus 3-25.5 JS Soaring 0 February 19th 08 07:49 PM
F.S. Nimbus 3 [email protected] Soaring 2 July 12th 06 02:35 PM
Nimbus 21C instrument panel Bill Daniels Soaring 10 October 13th 04 12:52 PM
Nimbus 4 Ray Gimmey Soaring 0 May 17th 04 06:46 PM
