Post Curing Composites
Old December 31st 18, 08:45 PM posted to rec.aviation.soaring
Default Post Curing Composites
I am looking for some advise regarding "Post Curing of Epoxy Composites".
The sailplane composite repairs have been completed regarding my salvaged ASW-27. The tail boom has a new 3'long intermediate section that has been scarfed and glassed into position. The fuselage pod had some radial cracks and the seat pan had some fractures that were all scarfed and glassed. All of the composite repairs were done at room temperature using OEM materials and MGS epoxy.
What temperature is recommended and for what duration should I be using for post curing the repaired areas. Is there a temperature ramp up and ramp down time that I need to work with. I plan to build a foam insulation box around the repair areas and use a fan with a number of light bulbs to regulate the temperature.
Any advise is greatly appreciated,
Chris
Old December 31st 18, 09:27 PM posted to rec.aviation.soaring
If my memory is correct. It is 55 C for 15 hours. I’ll confirm when I get back home this week. It is on most Schemp fiber plans.
Old December 31st 18, 09:40 PM posted to rec.aviation.soaring
Chris
The manual calls for 60 degrees C for minimum of 12 hours. You won't go wrong by going longer. It takes a couple hours for the structure to come up to temperature. Longer curing also helps reduce future shrinks showing up.
Make sure you monitor the temperature in a couple of spots.
I usually have a couple blankets to throw over everything if temp doesn't quite come up to target.
Good Luck
UH
Old January 2nd 19, 12:42 PM posted to rec.aviation.soaring
Per Carlin
It all depends om what Epoxysystem is used. I would be very carfull of post curing with heat without knowing what epoxies that is used. You can ruin the whole glider by overheating the structure.
Old January 2nd 19, 03:46 PM posted to rec.aviation.soaring
Paula
Am 02.01.2019 um 13:42 schrieb Per Carlin:
Yes, it depents on the Epoxy Systems (and all other materials in the
area). To make sure please refer to the data sheet of the systems in use.
As a guideline composite gliders are certified to temperatures up to 54
deg C.
Without specific background info of all materials in use I would post
cure at 50 deg C for 15-24h. You may ramp up the temperature to avoid
problems with only paritial cured epoxy (10h 30 deg C + 15h 50 deg C).
Paula
Old January 2nd 19, 04:57 PM posted to rec.aviation.soaring
Craig Lowrie
Hi Chris,
I build a cellotex box (building insulation material) and then use a
small bar heater placed low in the box. The Control is achieved using
a commercial Kiln controller which achieves the required temperature
from a thermocouple placed somewhere appropriate in the heat box,
and then controls the temperature to +/- about 1 degree by turning
the bar heater on and off. You can program the cure time and it cuts
it off at the end. I use a separate USB temperature monitor to get
the date to support the cure. Done about 25 cures with this system
now and no problems.... I have done most cures at temperatures of
55C but also done some specialist cures as high as 80C....
I think a fan approach might struggle into a sealed box....
Craig
Composites".=
=20
salvaged
A=
has been
s=
cracks
glassed. All
materials
and MGS epoxy.=20
be using
for=
and ramp
do=
box
ar=
regulat=
e the temperature.=20
Chris
Old January 2nd 19, 08:47 PM posted to rec.aviation.soaring
On Wednesday, January 2, 2019 at 11:00:06 AM UTC-6, Craig Lowrie wrote:
Hi Chris,
Craig
Composites".=
=20
salvaged
A=
has been
s=
cracks
glassed. All
materials
and MGS epoxy.=20
be using
for=
and ramp
do=
box
ar=
regulat=
Chris
Craig,
Are you using an infrared bar heater or something different. What size and type has been working for you. Have you had any problems with the overheat cut off protection.
Chris
Old January 2nd 19, 09:30 PM posted to rec.aviation.soaring
Hi Chris - you can find some technical date sheets that show the T-glass, E, and strengths that are available as a pull down in most of the MGS supplier sites (AC spruce, Wicks, etc). There can see the material changes when cured at both elevated temperatures and for different time durations. Really, do go with what a few others have said - the manufactures temp. At some point - refer to graphs, the increase in time will have very little effect at a constant temp. What you should pay attention to is not going to the extreme cure temps that the resin is capable of - then you could end up with a section of the boom with strengths and flex characteristics that vary from the original build. Basically a very stiff section between the original boom sections that will cause stress problems. And then it is a repair - easy to make stronger without much effort! I assume you have it in an alignment jig - it would be wise to keep it aligned as repaired and supported during the cure time.
Regards, Mark
Old January 2nd 19, 10:45 PM posted to rec.aviation.soaring
Craig Lowrie
Hi Chris,
I use an inexpensive bar heater... it has two bars... each about 6-8"
long... I
only use one unless the box is very large. It doesn't have an overheat
protection, but I did have to disable an orientation interlock so it can
lie flat...
open face up..!... The kiln controller is highly recommended to keep the
temperature under control.. but not cheap..!..
Craig
Hi Chris,
Craig
Composites".=
=20
salvaged
A=
has been
s=
cracks
glassed. All
materials
and MGS epoxy.=20
be using
for=
and ramp
do=
box
ar=
regulat=
Chris
Craig,
and
overheat
cut off protection.
Chris
Old January 2nd 19, 11:48 PM posted to rec.aviation.soaring
SF
I've spent a lot of my career either heating things up or trying to cool them off. Go with a low watt density heater, not anything that glows red. Maybe a milk house heater on low, at 60C you will have to disable the internal thermostat. Temperature distribution is going to be an issue, small circulation fans will help with that, you need some air movement, you don't need a lot. separate the fan and the heating element on the milk house heater and you get both in one package. TC's are cheap if you just buy the wire and make them your self, put a few extras on the structure you are heating, you can then spot check your temperature differences there will be more than you think. Sort things out at 40C, take it up to 60C after you are comfortable with what you have, including an automatic high temperature cutoff tested at a lower temperature. Automation direct has some pretty good $100 temperature controllers. This is one of those cases when Mo' ain't better. A well sealed foam board box with a few blankets over it isn't going to take a lot.
Questions on UV curing polyester resins. Fred the Red Shirt Home Built 4 March 21st 10 04:07 AM
Questions on UV curing polyester resins. Fred the Red Shirt Home Built 0 March 20th 10 07:23 PM
heater control for curing oven [email protected] Home Built 27 October 1st 05 07:03 PM
composites propeller Philippe Home Built 2 August 4th 04 10:45 AM
composites vs. aluminum John C Home Built 23 May 7th 04 04:31 AM
