Here's Why Airplanes Have Engines On The Wings Or On The Tail
Old June 1st 18, 05:18 PM posted to alt.binaries.pictures.aviation
Miloch
Default Here's Why Airplanes Have Engines On The Wings Or On The Tail
https://jalopnik.com/heres-why-airpl...5627#spbg4pc71
I’ve seen normally friendly and warm Jalopnik writers come to clumsy,
ineffective blows over the concept of car engine location. I came this close to
poisoning another writer’s coffee after I heard them say something disparaging
about rear engines, for example. It seems that the world of airplanes has some
similar issues! There’s two major places airliners place their engines, and this
video is one of the best explainers of why.
The two most common places for airliners to mount jet engines are under the
wings or at the rear of the aircraft. I’m sure anyone who’s been to an airport
has noticed this. The tradeoffs for each location are pretty fascinating, and,
while this video by Mentour Pilot is pretty long, it’s very informative. Here,
watch:
https://youtu.be/QqjZSHIKWzE
In case you’re seconds away from buying your first airliner and don’t have time
to watch the video, here’s a quick pro/con breakdown of the two types:
Wing Mount
Pro: Much easier engine access for service, can mount more and/or bigger
engines, less structural reinforcing needed, shorter fuel lines, safer in case
of engine fire
Con: High noise levels, susceptible to ground/foreign objects/debris damage,
requires larger rudder (in case one engine is lost)
Rear Mount
Pro: Quieter operation (from inside cabin), less likely to take in
debris/foreign objects, more suitable to more kinds of runways/airstrips, can
reverse aircraft on ground
Con: Harder to access for maintenance, requires more structural support and
longer fuel lines, more dangerous in case of fire
There’s more in the video, of course, including much more detail about handling
characteristics of each type of engine mounting.
It’s really interesting! Hearing a pilot talk about how planes handle makes
aviation much more familiar to us ground-based gearheads.
Sikorsky CH-53E Super Stallion pics [6/7] - A production CH-53E during flight demonstration showing the three engines and the tail rotor pylon.jpg (1/1) Miloch Aviation Photos 0 April 20th 18 01:11 PM
Bell P-63 Kingcobra pics 2 [4/7] - L-39 with swept wings, extended rear fuselage, ventral tail fin and P-39 prop.jpg (1/1) Miloch Aviation Photos 0 April 16th 18 01:49 PM
[VERY LONG} MD airplanes, complete and projects, engines, gliders, many other items. [email protected] Aviation Marketplace 0 June 10th 06 10:51 PM
Why are (some) delta wings stable without a horizontal tail? xerj Piloting 13 April 11th 06 02:38 AM
FS: Blanik L-13 Wings and tail feahers Burt Compton Soaring 0 December 13th 03 05:52 PM
