Want to go fly but "on call"
Old January 21st 19, 03:32 PM posted to rec.aviation.soaring
Default Want to go fly but "on call"
Want to go fly, but on call, any solutions?
Cell phone is obviously out, don't want to talk on the out while flying and they don't work much above pattern altitude anyway.
Willing to land in order to call back, just need a notification.
Old fashioned pager?
Any other means?
Thanks ðŸ˜
Old January 21st 19, 03:53 PM posted to rec.aviation.soaring
Richard DalCanto
Any other means?
Thanks ðŸ˜
Get someone to cover you for a couple hours, or carry a pager if you are willing to land.
Old January 21st 19, 04:09 PM posted to rec.aviation.soaring
Wyll Surf Air
Both the inReach Mini and the Spot X provide 2 way communication over text or email via a satellite link. They also have the added benefit of being satellite trackers so if you land out or bail out your crew, or EMS, can find you.
Old January 21st 19, 04:56 PM posted to rec.aviation.soaring
Ahhh
Thanks
I'll look into spot and inreach
Old January 21st 19, 05:21 PM posted to rec.aviation.soaring
Ahhh... Text messages
Any advice on how one could go about dragging the company and union into the 21st century and allowing modern means of communication?😣😣
Old January 21st 19, 10:32 PM posted to rec.aviation.soaring
Text via satellite is one thing (I have no experience in that), but cell is dependent. That I do have some experience in. Northern NJ, decent coverage (Verizon, a few years ago), maybe 5000AGL, sorta flat ground........hit or miss on sending a text in flight. I had to watch the signal strength start coming up, then hit send.
I figured out part of the issue was a CF cockpit, so holding the cellphone above the cockpit rail helped. This was in cruise flight, thermaling may have helped, may have hurt.....
PS, the only reason I did this was I had radio issues and I "wandered off" and nobody knew where I was. I figured a text back to someone at the field at least gave them a direction and intent (last contact with one of our club pilots was 10 miles north of Middletown, NY/home, I was now SW 20 or so miles out from home and continuing out).
Old January 22nd 19, 02:00 PM posted to rec.aviation.soaring
Rob Cluxton[_2_]
Been in that predictament a lot over the years. Thought about a Sat phone but they are pricey! Curious to know if there’s a way to automatically forward text messages from my cell to one of the latest trackers.
Solution also depends on if you’re on short or long call out window....and how far you want/can wander from home field. I’ve frequently ended up towing instead. Or resigned to stay low and close to home in the glider in order to still receive on my cell.
Good luck!
Rob
Old January 21st 19, 05:23 PM posted to rec.aviation.soaring
Ahhh...
Text messages
Any ideas how one could go about dragging the company and union into the 21st century?😡😡😡
Old January 21st 19, 05:57 PM posted to rec.aviation.soaring
gkemp
I would have my wife on the radio and my secretary could telephone her and she would relay to me .
Kemp NK
What are the Pros and Cons of using the "ForeFlight Mobile EFB" appin Sailplanes as opposed to, say, "iGlide" or "navITer" ? jstodaro Soaring 4 March 26th 17 05:04 PM
Have you been asked to "Call the tower"? Jay Honeck[_13_] Piloting 12 November 11th 10 03:22 PM
"VideO Madness" ( Soldiers...) "GoD Hates FAGS!!! (He sO righteOusly DoES)" Colonel Jake Naval Aviation 0 March 1st 10 12:14 AM
OTA -- a new twist to "call me when you land" Roy Smith General Aviation 6 June 15th 06 06:02 AM
Tried to Call it "Runway 7" today... Jay Honeck Piloting 34 October 21st 05 05:24 PM
