Ox Cylinder ASW27
Old January 22nd 19, 12:09 AM posted to rec.aviation.soaring
Gary Wayland
Default Ox Cylinder ASW27
Can someone tell me what is the largest Oxygen cylinder that will fit in an ASW27?
Thanks for the help...
Old January 22nd 19, 12:48 AM posted to rec.aviation.soaring
Scott Williams
I think I know what U.S. available bottle fits if it is the same as an ASG-29
Scott
Old January 22nd 19, 01:01 AM posted to rec.aviation.soaring
Matt Herron Jr.
contact Rex at Williams Soaring in Williams, CA. He has some that barely fit
Old January 22nd 19, 01:59 AM posted to rec.aviation.soaring
S9
Just today I fitted the following oxygen bottle in my ASG-29... The glider has a mounting set up for 108mm max diameter. This bottle is a little smaller about 101mm - but be sure to verify any bottle you obtain... Luxfer M15A-5
Old January 22nd 19, 02:16 AM posted to rec.aviation.soaring
Gary Wayland
Thanks, Gentlemen for the information.
I hate to call Paul Remde and others since they have so many gliders they have to remember and with different sizes. I never owned a tank being on the East Coast.
And, I'm not going to use it for OX, but for another application. I'm doing a 3D printing first so this why I need the Max diameter.
Thanks again, I really appreciate the help.
Gary
Old January 22nd 19, 04:47 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
Gary,
I assume by largest you mean diameter, not length. I am also assuming that you want to find/buy an O2 bottle to fit an ASW-27. You know what they say about assuming.
After I bought my ASW-27 I had to do some major league searching to find a bottle that would fit my ship. Took more than a year to find one. Luckily a friend that owns an ASW-24 lent me his bottle for a western trip. Thanks, Geoff.
Bottom line is that the critical dimension is the diameter (no duh) which, to me, is rather difficult to measure accurately unless you have a particularly large caliper hanging around. Accurate measuring is especially dicey when you are asking a seller of unknown resources/capabilities to measure their bottle.
So, using my friend's bottle, I came up with the following CIRCUMFERENCE which is much easier to measure accurately. This I could then give to prospective bottle providers for them to measure what they have in stock before purchasing.
Here is what I came up with;
Circumference = 13-5/32" = 13.15625" = 334.2mm
QED Diameter = 4-3/16" = 4.1875 = 106.4mm
So, how to have someone else easily accurately measure circumference? A carpenter's steel measuring tape will NOT wrap around a cylinder. A tailor's cloth tape is great but is much less likely have be available. The easiest way I found is to have the seller wrap a (long narrow) piece of paper around the bottle, mark where the edges meet, lay the paper out flat on a table, and then accurately measure between the marks with a simple flat ruler (preferably in metric as +/- 1mm is ok but counting 16ths of a inch is more prone to error - ask me how I know).
Be prepared to suffer multiple disappointments in your search.
My overblown $0.02,
John OHM Ω
PS - Asking the ASW-27 Yahoo group may dredge up something for you. https://groups.yahoo.com/neo/groups/ASW27owners
Or post to http://glidersource.com which is where I ultimately found my bottle.
Old January 22nd 19, 05:54 PM posted to rec.aviation.soaring
Gary, be specific on which AS design and serial number you need to fit. The US bottle diameter normally used for sailplane O2 systems increased a few years back and this created a SNAFU with some Schleicher designs. Research Yahoo's ASW-27 owners group as it has specifics. I'm probably wrong but perhaps Schleicher enlarged the cylinder well somewhere along in productions.
On Tuesday, January 22, 2019 at 11:48:01 AM UTC-5, OHM Ω http://aviation.derosaweb.net wrote:
Gary,
My overblown $0.02,
John OHM Ω
Old January 22nd 19, 07:41 PM posted to rec.aviation.soaring
Gary Wayland
On Tuesday, January 22, 2019 at 12:54:08 PM UTC-5, wrote:
Gary, be specific on which AS design and serial number you need to fit. The US bottle diameter normally used for sailplane O2 systems increased a few years back and this created a SNAFU with some Schleicher designs. Research Yahoo's ASW-27 owners group as it has specifics. I'm probably wrong but perhaps Schleicher enlarged the cylinder well somewhere along in productions..
Gary,
My overblown $0.02,
John OHM Ω
My ASW27 is 27-148
Once I get the 3D printed bottle completed, I will reveal what the actual dimensions are for future owners, i.e perfect fit or room to grow... At least we will know the largest you are going to get in the hole...
Old January 23rd 19, 12:28 AM posted to rec.aviation.soaring
The option is to get a European bottle from Schleicher and use an adapter (DIN-CGA) from mountain high to fit a USA style regulator and to fill.
I have done this with our ASW28 and ASG29.
Tom
Old January 24th 19, 08:46 PM posted to rec.aviation.soaring
Gary,
Do you just need to know the OD of a bottle that will fit? I can measure up my bottle for you if that's all you need.
The last time I got involved in this was 2014, at that time Norris Cylinders in AL could supply a cylinder that fit the 27. But they had some old inventory from purchasing Worthington in Canada that were supposed to be the same cylinder but the OD was just a bit larger (QA/Spec/Tooling issue) making it not fit the rear cuff glued to the side of the gear enclosure on the 27. So if you go the Norris route you need to get them to check the cylinder OD just in case the old Worthington inventory is still a problem.
I identified a possible alternative that might work with the addition of a thin plastic sleeve on the bottom to enlarge to OD slightly it was a Luxfer M15A composite cylinder.
I ended up with a steel cylinder that fit from Norris via John Murray at Eastern. Calling John, Then Rex, then Norris would probably turn up a cylinder that fits.
SF
Oil in cylinder, other cylinder issues Robert M. Gary Owning 8 May 27th 07 05:26 AM
Oil in cylinder, other cylinder issues Jim Burns[_3_] Piloting 2 May 24th 07 05:26 AM
Oil in cylinder, other cylinder issues Jim Burns[_3_] Owning 2 May 24th 07 05:26 AM
Oil in cylinder, other cylinder issues Robert M. Gary Piloting 0 May 23rd 07 10:44 PM
Oil in cylinder, other cylinder issues Robert M. Gary Owning 0 May 23rd 07 10:44 PM
