Supermarine Seafire
about the video: Seafire deck operations...Royal Navy, circa 1943 A Royal Navy partially-dramatised presentation showing Seafire IIC fighters operating from an escort carrier. https://en.wikipedia.org/wiki/Supermarine_Seafire The Supermarine Seafire was a naval version of the Supermarine Spitfire adapted for operation from aircraft carriers. In concept, it is relatively comparable to the Hawker Sea Hurricane, a navalised version of the Spitfire's stablemate, the Hawker Hurricane. The name Seafire had been derived from the abbreviation of the longer name Sea Spitfire. The idea of adopting a navalised carrier-capable version of the Supermarine Spitfire had been mooted by the Admiralty as early as May 1938. Despite a pressing need to replace various types of obsolete aircraft that were still in operation with the Fleet Air Arm (FAA), some opposed the notion, such as Winston Churchill, although these disputes were often a result of an overriding priority being placed on maximising production of land-based Spitfires instead. During 1941 and early 1942, the concept was again pushed for by the Admiralty, cumulating in an initial batch of Seafire Mk Ib fighters being provided in late 1941, which were mainly used for pilots to gain experience operating the type at sea. While there were concerns over the low strength of its undercarriage, which had not been strengthened like many naval aircraft would have been, its performance was found to be acceptable. From 1942 onwards, further Seafire models were quickly ordered, including the first operationally-viable Seafire F Mk III variant. This led to the type rapidly spreading throughout the FAA. In November 1942, the first combat use of the Seafire occurred during Operation Torch, the Allied landings in North Africa. In July 1943, the Seafire was used to provide air cover for the Allied invasion of Sicily; and reprised this role in September 1943 during the subsequent Allied invasion of Italy. During 1944, the type was again used in quantity to provide aerial support to Allied ground forces during the Normandy landings and Operation Dragoon in Southern France. During the latter half of 1944, the Seafire became a part of the aerial component of the British Pacific Fleet, where it quickly proved to be a capable interceptor against the feared kamikaze attacks by Japanese pilots which had become increasingly common during the final years of the Pacific War. The Seafire continued to be used for some time after the end of the war. The FAA opted to promptly withdraw all of its Merlin-powered Seafires and replace them with Griffon-powered counterparts. The type saw further active combat use during the Korean War, in which FAA Seafires performed hundreds of missions in the ground attack and combat air patrol roles against North Korean forces during 1950. The Seafire was withdrawn from service during the 1950s. In FAA service, the type had been replaced by the newer Hawker Sea Fury, the last piston engine fighter to be used by the service, along with the first generation of jet-propelled naval fighters, such as the de Havilland Vampire, Supermarine Attacker, and Hawker Sea Hawk. The Spitfire's original role, in which it proved formidable, was that of short-range land-based interceptor. As a carrier based fighter, the design was a compromise and suffered many losses through structural damage that was inflicted by heavy landings on carrier decks: a problem that continued even with the strengthening introduced by the Mk II. The Seafire had a narrow undercarriage track, which meant that it was not well suited to deck operations. The many modifications had shifted the centre-of-gravity aft, making low-speed control difficult and the aircraft's gradual stall characteristics meant that it was difficult to land accurately on the carrier, resulting in many accidents. Other problems included the basic Spitfire's short range and endurance (fine for an interceptor fighter but not for carrier operation), limited weapons load and that it was dangerous in ditching. The first Seafire variant to overcome many of these problems was the Mk XVII with its new undercarriage design, reinforced structure and extra fuel tanks, although there were still some compromises and it entered service well after the war was over. The low point of Seafire operations came during Operation Avalanche the invasion of Salerno in September 1943. Of the 106 Seafires available to the British escort carriers on 9 September only 39 were serviceable by the dawn of D-Day plus Two (11 September). Part of this was attributed to the flat, calm conditions present, which meant that there had not been enough headwind in order to adequately slow down the Seafires on landing. Many aircraft missed picking up the arrestor wires and flew into the crash barriers while others had their arrestor hooks pulled off the fuselage because they caught the wires at too high a speed. In spite of these problems, the Seafires (especially the L Mk IIs and L Mk IIIs, with their low altitude rated Merlin engines) were used to patrol the vicinity of the carrier fleet as protection against low altitude attackers, while the longer ranging fighters, such as the Grumman F6F Hellcat, took on a similar role further out and at higher altitudes. Role Carrier-based fighter Manufacturer Supermarine First flight 7 January 1942 Status Retired Primary users Royal Navy French Navy Irish Air Corps Royal Canadian Navy Number built 2,646 Developed from Supermarine Spitfire During 1942 and into 1943, FAA squadrons progressively converted to the Seafire, eventually replacing the Sea Hurricane in front-line service. In the Fleet Air Arm, Spitfires and Seafires were used by a number of squadrons, the Spitfires used by training and land based squadrons. Twelve 800 series squadrons used Spitfires and Seafires (Numbers 801 NAS, 802 NAS, 808 NAS, 809 NAS, 879 NAS, 880 NAS, 884 NAS, 885 NAS, 886 NAS, 887 NAS, 897 NAS and 899 NAS). Several units of the Royal Naval Volunteer Reserve also flew Seafires postwar, including 1831, 1832 and 1833 squadrons. In November 1942, the first combat use of the Seafire occurred during in Operation Torch, the Allied landings in North Africa, from the decks of several escort and fleet carriers; unusually, Seafires flew with American star markings during the operation, these were removed following their withdrawal from the theatre. In July 1943, the Seafire was used to provide air cover for the Allied invasion of Sicily; and reprised this role in September 1943 during the subsequent Allied invasion of Italy, being used to maintain continuous air cover of the beachheads, the type being almost entirely responsible for this task. During the latter operation, around half of the taskforce's Seafires were inoperable within four days, primarily due to landing accidents. During the latter half of the war, the Seafire saw increasing service as part of Britain's contribution to the Far East Pacific campaigns, serving with No. 887 and 894 Squadrons, Fleet Air Arm, aboard HMS Indefatigable and joining the British Pacific Fleet late in 1944. As range quickly became a detrimental factor in Pacific operations, Seafires in this theatre were often fitted with additional fuel tanks previously used by Curtiss P-40 Warhawks. Due to their good high altitude performance and lack of ordnance-carrying capabilities (compared to the Hellcats and Corsairs of the Fleet) the Seafires were allocated the vital defensive duties of Combat Air Patrol (CAP) over the fleet. During May 1945, Seafires were used to cover the Allied landings at Rangoon for Operation Crimson. Seafires were thus heavily involved in countering the kamikaze attacks during the Okinawa landings and beyond. The Spitfire was operational in the Pacific Fleet right up to VJ Day, being used off the coast of Japan during the final months of the war. The Seafires' best day was 15 August 1945, shooting down eight attacking aircraft for one loss. During the campaign 887 NAS claimed 12 kills and 894 NAS claimed 10 kills (with two more claims earlier in 1944 over Norway). The top scoring Seafire pilot of the war was Sub-Lieutenant R.H. Reynolds DSC of 894, who claimed 4.5 air victories in 1944–5 Specifications (LF Mk III) General characteristics Crew: one Length: 30 ft 2½ in (9.21 m) Wingspan: 36 ft 10 in (11.22 m) Height: 11 ft 5 in (3.48 m) Wing area: 242.1 ft² (22.5 m²) Empty weight: 6,204 lb (2,814 kg) Max. takeoff weight: 7,640 lb (3,466 kg) Powerplant: 1 × Rolls-Royce Merlin 55M liquid-cooled V-12, 1,585 hp (1,182 kW) Performance Maximum speed: 359 mph (578 km/h) at 5,100 ft (1,554 m) Cruise speed: 218 mph (351 km/h) Range: 513 mi (825 km) Service ceiling: 32,000 ft (9,754 m) Rate of climb: 1.9 min to 5,000 ft (1,525 m) * |
UK2 SX311 Supermarine Seafire HMS Triumph.jpg | Joseph Testagrose | Aviation Photos | 0 | August 9th 14 12:53 PM |
UK2 SX165 Supermarine Seafire 1949-09-22 HMS Illustrious.jpg | Joseph Testagrose | Aviation Photos | 1 | August 9th 14 12:42 AM |
UK2 NN300 Supermarine Seafire 1945 HMS Hunter.jpg | Joseph Testagrose | Aviation Photos | 0 | October 24th 12 02:07 PM |
UK2 NF547 Supermarine Seafire HNielsonPhoto.jpg | Joseph Testagrose | Aviation Photos | 0 | October 18th 12 01:24 PM |
UK2 MB218 Supermarine Seafire 1943-02orLater HMS Attacker MickBurrowColl.jpg | Joseph Testagrose | Aviation Photos | 0 | December 23rd 11 11:21 AM |
