Alternator (Ammeter) Problem (Piper)
Old February 4th 19, 12:06 PM posted to rec.aviation.owning
Default Alternator (Ammeter) Problem (Piper)
On Sunday, August 27, 2000 at 11:05:49 AM UTC+10, Rick Potts wrote:
I replaced the alternator in my Warrior (PA 28-151) this week and the
prior problem (the alternator dropping offline periodically, up until
the time it dropped offline and refused to come back on 200 miles from
home) has been replaced by a new problem.
The good news is the new alternator came online when I started the
Warrior's engine this morning and, according to the ammeter, started
producing electricity.
The bad news is the ammeter needle then started to wiggle back and
forth across the dial like a windshield wiper, from "0" on the left to
about "30" on the right, about two times per second. Varying the
engine speed didn't make a difference in how it behaved.
I measured the battery voltage (at the cigarette outlet) and it
remained steady at 14 to 15 volts. It didn't fluctuate at all, even
though the ammeter needle was dancing all around.
The Piper Service Manual's troubleshooting chart says that "excessive
ammeter fluctuation" can be caused by a defective voltage regulator or
excessive resistance in the field circuit. I hesitate to blame the
voltage regulator when the voltage stays so steady, so is "excessive
resistance" the likely culprit?
For "excessive resistance" the manual recommends: "Check all
connections and wire terminals in field circuit for deterioration such
as loose binding posts, broken wire strands at terminals, etc..
Tighten all connections and replace faulty terminals."
I'm no expert at reading electrical diagrams, but it appears the
"field circuit" would include the voltage regulator, the overvoltage
relay and the alternator switch. The output side would include the
ammeter and a large (6 gauge?) wire that runs to the battery
contactor.
The voltage regulator and the overvoltage relay are mounted up under
the instrument panel, so getting to them won't be easy. The alternator
switch, on the other hand, is quite easy to get to so I think I'll
start there.
Question: How is the split master switch mounted? Does the plastic
cover piece come off the instrument panel with the switch mounting
from the front? Or do I have to remove it from the rear somehow? I'd
like to get in there to clean and tighten whatever connections are
there.
Or is the voltage regulator still a potential culprit?
Thanks for any ideas!
Rick Potts Phoenix, Arizona
N32334 PA 28-151 Warrior
Hi,
I have encountered a problem with my PA28 Archer II where the Alt Light comes on and off and showing that it is charging between 13 to 14.8 volts, I have replaced the voltage regulator with a brand new unit it is still doing the same thing, also I tried a test where you by pass the over voltage regulator still the same signs, I have also changed the alternator with a serviceable unit and it also had the same symptoms, any one out there ever had this issue?
any insight would be appreciated
Cheers
Bill Q
Old February 8th 19, 06:40 AM posted to rec.aviation.owning
contactor.
start there.
there.
Hi,
Cheers
Bill Q
I'm having the exact same problem with my Tomahawk PA-38-112. Replaced the battery, voltage regulator, cleaned all the ground connections, no go..My alternator voltage is reading high (15.5 volts) with a pulsing ammeter..looking for help also..
Thanks Greg
Alternator (Ammeter) Problem (Piper) [email protected] Owning 3 October 29th 18 09:55 PM
Piper Seneca II Alternator circuit problem George Jerome Owning 0 June 5th 17 03:39 AM
Yet another alternator problem Chris Kennedy Owning 7 July 16th 04 05:28 PM
Alternator problem Tom Jackson Owning 18 April 26th 04 05:42 PM
Piper PA 12 Ammeter Jeff Restoration 0 November 18th 03 02:50 AM
