Noise Canceling headset
Old February 5th 19, 03:11 PM posted to rec.aviation.soaring
Default Noise Canceling headset
What is the best value noise canceling headset for a motor glider.
Since the back seat persons head in only inches from the motor - I want to protect their hearing.
WH
Old February 5th 19, 03:48 PM posted to rec.aviation.soaring
Craig Reinholt
WH
I use the Bose QuietComfort® 20 Acoustic Noise Cancelling® earbuds. That, with a 3.5mm to 4.5mm jack adapter works nicely. For me, earbuds are better than a headset because of limited space to hang / store a headset after climbing out. BTW, they are great on long commercial flights to cancel the engine noise and are comfortable to wear. Craig
Old February 5th 19, 05:08 PM posted to rec.aviation.soaring
jfitch
WH
+1 on the Bose. I've been using them for years. Started out just during engine runs, now I wear them the entire flight, cuts down on the wind noise, makes radio reception at high speed perfect. No room in my 26Mi for a big headset.
Old February 5th 19, 05:46 PM posted to rec.aviation.soaring
JS[_5_]
WH
Another advantage of earbuds: They don't scratch the canopy when being donned or removed. Less polishing.
Old February 8th 19, 07:36 PM posted to rec.aviation.soaring
Craig Reinholt
One correction. The adapter for the Bose QC20 earbuds to use with standard USA aviation female audio jacks is a 3.5 mm female to 6.35 (1/4 inch) male stereo adapter.
Here is one example.
https://www.amazon.com/Homyl-2Pieces...tronics&sr=8-9
Old February 8th 19, 07:46 PM posted to rec.aviation.soaring
Thanks for the help- I just ordered them!
WH
Old February 5th 19, 06:40 PM posted to rec.aviation.soaring
Rick Lederman
I use the Bose A20 in my Stemme S12. I am just over six feet tall with a long torso so the thick headband can touch the canopy so I rest the headband on the bill of my hat. It looks stupid but works, and beauty is as beauty does.
I tried the Bose Proflight Aviation headset with ear buds, as Bose will tell you, the noise reduction is not nearly as good as the A20, and not nearly enough for the S12. They were simply terrible in my Stemme. Bose was great and took them back with a full refund.
Old February 5th 19, 06:43 PM posted to rec.aviation.soaring
From a base of no prior knowledge I too have looking into noise cancelling headsets for a self launching glider. Those Bose earbuds sound good but I figured that a noise cancelling microphone was as, if not more, important as the speakers (??) because in the ASH 26e I have flown recently I had problems making myself understood on the radio with a normal boom microphone when the engine was running.
I have been looking for a lightweight compact conventional headset and currently I am considering the Telex Airman 8 ANR headset (with a noise cancelling microphone and ANR earphones) which looks to be substantial enough to survive glider cockpit life but not too bulky. Reviews of this suggest it is not as good as full size top name headsets for professional use but hopefully enough for short term use during engine runs.
Old February 5th 19, 07:17 PM posted to rec.aviation.soaring
Gary Wayland
WH
A set of headphones has to be a big item in the cockpit of a glider.
What about earplugs you use at the gun range? The last thing I want is headphones on when I 'm soaring and listening to the air around me. So, for the small amount of time served by the headphones for engine noise, is this worth it?
I have the Bose for the Helicopter and it is a must in that contraption!
Just Curious...
Gary
"SQ"
Old February 5th 19, 07:28 PM posted to rec.aviation.soaring
WH
Just Curious...
Gary
"SQ"
In my limited SLS experience without a headset I find it difficult to make and receive intelligible lining up and take off calls.
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Piloting 26 January 13th 07 12:06 AM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Instrument Flight Rules 15 January 13th 07 12:06 AM
UPDATE #3 -- Headset Noise Jonathan Goodish Owning 15 April 25th 06 05:36 AM
Headset Noise Jonathan Goodish Owning 31 April 19th 06 01:18 PM
UPDATE -- Headset Noise Jonathan Goodish Owning 7 April 18th 06 05:43 PM
