GPS week rollover issue
Old February 6th 19, 05:00 PM posted to rec.aviation.soaring
Jonathan Foster
Default GPS week rollover issue
I just came across this interesting page: https://www.orolia.com/resources/blo...-you-need-know
On April 6th of this year the GPS week will roll over and on some older instruments it could mess up the date. How many of our soaring instruments might have this problem?
Jonathan
Old February 6th 19, 05:27 PM posted to rec.aviation.soaring
kinsell
Jonathan
There's some potential for problems, but some of the firmware has been
hacked to delay the actual appearance of the problem for years in the
future. I doubt there's going to be a big ripple of problems in April.
Old February 6th 19, 05:39 PM posted to rec.aviation.soaring
Tim Newport-Peace[_4_]
instruments
Jonathan
Any of them, but the older instrument the more likely it is to have a
problem.
The date is transmitted by the satellite as a day oy the week and a week
number. there are 11 bits available for the week number (0-1023) and a
rollover occurs every 1024 weeks (an Epoch) or 19 years 8 months approx.
As the GPS engine in the instrument does not receive the Epoch number from
a satellite, it relies on a Battery Maintained Real Time Clock on the GPS
Engine module. If the battery fails or is allowed to become discharged,
Epoch 0 may be assumed, which it probably isn't. Epoch 0 started 6th Jan
1980 originally, but some recorders may have a different date set to fix
previous rollover problems.
The RTC battery should hold up for six months or so, but as the battery
becomes older, the capacity may decrease, reducing the figure. The best
advice seems to be to connect your instrument just before 6th April to
allow the GPS Engine battery to charge. And pray. If you Recorder has the
right date after 6th April 2019 all is well and good, but never allow the
RTC battery to become discharged.
If you have the wrong date after 6th April, it is a Return-to-Manufacturer
repair.
Good Luck!
Old February 6th 19, 05:56 PM posted to rec.aviation.soaring
Jonathan Foster
Tim, thanks for that explanation. Is this what happened to the Cambridge instruments that needed an update to keep working several years ago?
On Wednesday, February 6, 2019 at 10:45:04 AM UTC-7, Tim Newport-Peace wrote:
instruments
Jonathan
problem.
repair.
Good Luck!
Old February 6th 19, 06:40 PM posted to rec.aviation.soaring
Dan Marotta
My old Cambridge gps had to be sent back to be reset.Â* What about the
ClearNav or PowerFlarm portable?
instruments
Jonathan
problem.
repair.
Good Luck!
Dan, 5J
Old February 6th 19, 10:05 PM posted to rec.aviation.soaring
A number of Legacy Cambridges had problems. They use the Garmin GPS25
Engine and lets face it, the batteries are very old now. I believe that CAI
replaced the GPS Engine, which includes the RTC Battery.
ClearNav are more recent by far, so are unlikely to be affected.
I'm not sure about Flarm, why not ask them?
Tim.
Cambridge
older
instruments
Jonathan
problem.
week
approx.
from
GPS
discharged,
Jan
fix
battery
best
repair.
Good Luck!
Dan, 5J
Old February 7th 19, 12:03 AM posted to rec.aviation.soaring
Tango Eight
I'll post information pertinent to ClearNav products here and on the CN user forum as soon as I have the official story.
-Evan
Tim.
Cambridge
older
instruments
Jonathan
problem.
week
approx.
from
GPS
discharged,
Jan
fix
battery
best
repair.
Good Luck!
Dan, 5J
Old February 7th 19, 02:57 AM posted to rec.aviation.soaring
Bruce Hoult
I'm guessing that will be the final end of my 1994 Cambridge Model 10. (It's already had the battery replaced, of course)
Old February 8th 19, 06:43 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Nah, Bruce. I bet if your GPS battery is still good, it will survive this one the same way it survived the first one. The problems didn't show up immediately on the first roll-over. They showed up when the old GPS batteries started to age out. At least, that is what I remember. May need to replace my memory battery. :-)
At least, that is my current gamble. Just mailed 4 Model 20s to Gary to get that GPS battery replaced!
Steve Leonard
Old February 9th 19, 03:16 AM posted to rec.aviation.soaring
kinsell
I've got a 1996 era Garmin backpacker gps still holding the correct
date. Internal battery was replaced under warranty about 22 years ago.
I'd be surprised if it suddenly got the wrong date on April 6, but
really doesn't matter anyway. Lots of old Volksloggers got hit with the
date problem, maybe they'd be more subject to failure if any of them are
still in use.
Illegal Immigration, the Non-Issue of the Week?????????????? Expert Humor Owning 0 March 31st 06 05:14 AM
Illegal Immigration, the Non-Issue of the Week?????????????? Expert Humor Home Built 0 March 31st 06 05:12 AM
Illegal Immigration, the Non-Issue of the Week?????????????? Expert Humor Piloting 0 March 31st 06 05:04 AM
Illegal Immigration, the Non-Issue of the Week........................ Expert Humor General Aviation 0 March 31st 06 04:55 AM
Illegal Immigration, the Non-Issue of the Week........................ Expert Humor Naval Aviation 0 March 31st 06 04:50 AM
