Scotchgarding slightly weathered wingcovers
Old February 25th 19, 02:54 PM posted to rec.aviation.soaring
Retting
Default Scotchgarding slightly weathered wingcovers
I have the lower cost Chinese wing covers and after 3 days of drizzle they appeared to be somewhat internally saturated, sticking to wing.
Not sure how much if any water is getting thru as everything is damp. When the sun finally appeared, the covers seemed to dry fast enough.
With all of that I was pondering the idea of Scotchgarding with Heavy Duty Water Shield 3M. Formulated for outdoor fabrics of all kinds. Tents, boat covers, canvas, etc.
Anyone have any experience with Scotchgard? I could do the tailboom area only and see how it performs.
R
Old February 25th 19, 05:18 PM posted to rec.aviation.soaring
Tom Kelley #711
R
Don't use my covers very often but I do reapply every 3 years(or so) "Starbrite waterproofing" which I purchase in a gallon size from Amazon. I do use a mask when applying. The best test to see if it's needed is to try and simply blow air thru the material. If you can do that, then you really should use the waterproofing. UV does take its toll and we found over the years Starbrite lasts the best for our use. Either spray it on or you can use a brush to do it.
QT is at Seminole, talk with him as he did his several years ago when I also was doing mine.
Best. #711.
Old February 28th 19, 04:09 PM posted to rec.aviation.soaring
john firth
R
Starbright lasts 2-3 years; a roller is much easier to use than a brush.
Do the job in open air; both the solvent and the active ingredient
are bad for the body.
JMF
Gatorade (only slightly OT) Martin Gregorie[_5_] Soaring 23 June 5th 10 04:50 PM
Not quite bush flying- weathered in on the Liard River Capt. Geoffrey Thorpe Aviation Photos 0 January 18th 09 11:43 PM
Slightly OT, How do birds fly IMC? Ricky Piloting 37 June 2nd 08 02:20 PM
slightly OT - NASA ER-2 Skywise Piloting 23 April 25th 06 12:36 AM
slightly off topic Rick Pellicciotti Home Built 0 March 15th 04 02:10 AM
