DUO DISCUS REAR SEAT
Old November 15th 04, 02:09 AM
Gordon Schubert
Default DUO DISCUS REAR SEAT
I am going to be flying in a Duo Discus from the rear
seat in the near future. Since I am fairly large, 6'1',
245lbs, I am wondering about the weight limitations
and the size of the rear seat. Can anyone help?
Thanks!
GORDY
Old November 15th 04, 02:22 AM
Marc Ramsey
You are probably over the seat weight limitation with a parachute, but a
co-owner of another Duo out here weighs more. There's plenty of room in
the back (but not the front). We re-rigged the rear rudder pedals so
they lean farther forward than the stock position (they are still within
the tolerances specified by the maintenance manual). This makes the
rear seat more comfortable for taller pilots.
Marc
Old November 15th 04, 10:54 AM
John Galloway
My ex syndicate Duo had a front and rear seat load
maximum limit of 110kg irrespective of C of G position.
Perhaps read the small print on the glider insurance
before flying outwith the terms of the type certificate
- if that is the case.
John Galloway
6'1',
a parachute, but a
plenty of room in
rudder pedals so
are still within
This makes the
Marc
Old November 18th 04, 03:05 AM
Tim Gossfeld
Gordon,
The Duo is placarded for a maximum of 243 lbs in the rear seat. Have fun.
Old November 18th 04, 08:39 AM
John Galloway
At 03:36 18 November 2004, Tim Gossfeld wrote:
Gordon,
=110Kg.
=2lbs less than the pilot without chute
Airliner Seats ... smjmitchell General Aviation 6 September 26th 04 10:00 PM
Discus 2b cockpit comfort? Jeremy Zawodny Soaring 11 January 12th 04 08:03 PM
All Czech built Discus grounded Paul Soaring 0 September 14th 03 02:22 AM
18m Discus Burt Compton Soaring 2 September 8th 03 10:52 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
