ASK13 hangar ceiling
Old March 10th 19, 01:43 PM posted to rec.aviation.soaring
Default ASK13 hangar ceiling
We want to hang up our ASK13 in our hanger.
Our ASK13 has a nose wheel and glass fuselage modification, that is why a rope or a band/strap hang is not possible.
We know there are 2 holes on the outside of the fuselage around the mid section of the cockpit.
Maybe this can be an option for hanging?
Does anyone have any suggestions or experiences with this particular case?
Let me know.
Lars
Old March 10th 19, 04:27 PM posted to rec.aviation.soaring
Burt Compton - Marfa Gliders, west Texas
Those two L & R holes are metric threaded and serve two purposes.
Threaded tie down rings for securing outside.
Attached points for the trailer dolly under the fuselage.
(Keep the threads clean or fly with the rings inserted fully. Make sure they do not back out of the fuselage.)
Used as tie down rings, they are original equipment and very substantial.
Whether you want to suspend the ASK-13 from these rings is up to you.
The other hang points might be the left and right handles on the fuselage.
I am NOT saying that these points are designed to sustain the weight without damage to the fuselage structure.
If you hang a glider ropes at the wingtips will be needed to keep one wing from dipping vertically and swinging horizontally when (not if) wind gets into the hangar.
In my experience, the disadvantage to hanging a glider is that the effort to lower and raise it discourages frequent flying!
Blanik L13 VS ASK13 handling and aerodynamics ? Matthieu Soaring 1 August 2nd 10 12:59 AM
Avgas Where is the ceiling? Doug Palmer Owning 217 May 8th 06 08:55 PM
To hang up a glider to hangar's ceiling Paolo Ceccarelli Soaring 1 March 7th 05 07:00 AM
service ceiling of F-22 zxcv Military Aviation 7 March 14th 04 10:31 PM
Class C Ceiling Mzsoar Soaring 1 August 18th 03 08:50 PM
