Need CO analyzer for motorglider tuning
Old November 21st 04, 11:37 PM
Eric Greenwell
Default Need CO analyzer for motorglider tuning
The Schleicher factory uses a CO analyzer to tune the Wankel motor in
their self-launching gliders. I'd like to do it this way, as it gets a
good tuning more easily and quickly than the usual fiddling around with
the needle valves until everything is running right.
It requires a unit that can measure up to 8% CO. My problem is the
suitable units I can find are quite expensive, with the cheapest at
$2000US. These are automotive units which go to the 8% range, not the
much cheaper furnace and combustion meters that only go to 0.2% or so.
Does anyone know of a cheaper unit, or where good used ones might be
purchased? We've tried the $220 "Gastester" unit, and it is unsatisfactory.
Eric Greenwell
Washington State
USA
Old November 22nd 04, 12:05 AM
Stefan
Eric Greenwell wrote:
My problem is the suitable units I can find are quite expensive,
When I need professional and expensive equipment, I usually try to rent
it from a pro.
Stefan
Old November 22nd 04, 08:48 AM
Michel Talon
Isn't it possible to arrange with an automotive mechanics to do the
tuning for a small fee? Here nearly all these people have a CO analyzer.
Michel TALON
Old November 22nd 04, 09:14 PM
Eric Greenwell
I tried this initially, but nobody wanted a 60 foot glider assembled in
their parking lot, blowing a lot of air and dust around, nor did they
feel it was safe. I don't blame them - when you are standing 3 feet from
a 5 foot propeller turning 2000+ rpm at full throttle, it really gets
your attention! They also were uneasy about doing work on an aircraft,
since they are not certified for that.
I also tried to borrow or rent one of these instruments, but the only
ones I could locate were not portable: they were part of a heavy,
roll-around cabinet that weighed over 150 pounds, contained several
instruments, and could not be conveniently taken to the airport (or
anywhere). Nor did any of the owners want to let a $4000-$5000
instrument that they depended on for their employment leave their sight!
There are enough (25 or so) ASH 26 owners in the US that some of us
could buy a CO analyzer together, then ship it around the country as
needed. This might be only 3 or 4 times a year, as the engine doesn't
need tuning very often. Sharing ownership would cut the individual's
cost to less than $150. If we can locate a suitable instrument, that's
how we'll likely proceed.
Eric Greenwell
Washington State
USA
Old November 23rd 04, 01:43 AM
Atacdad
Eric,
You might check through a local Mazda RX club for a local rotary guru with a
shop...they just might be intrigued enough to give it a shot. You might
sniff around www.rx8-club.com as well. Us rotary owners are a clannish
lot....
AT
their parking lot, blowing a lot of air and dust around, nor did they feel
it was safe. I don't blame them - when you are standing 3 feet from a 5
foot propeller turning 2000+ rpm at full throttle, it really gets your
attention! They also were uneasy about doing work on an aircraft, since
I also tried to borrow or rent one of these instruments, but the only ones
I could locate were not portable: they were part of a heavy, roll-around
cabinet that weighed over 150 pounds, contained several instruments, and
could not be conveniently taken to the airport (or anywhere). Nor did any
of the owners want to let a $4000-$5000 instrument that they depended on
There are enough (25 or so) ASH 26 owners in the US that some of us could
buy a CO analyzer together, then ship it around the country as needed.
This might be only 3 or 4 times a year, as the engine doesn't need tuning
very often. Sharing ownership would cut the individual's cost to less than
$150. If we can locate a suitable instrument, that's how we'll likely
proceed.
Eric Greenwell
Washington State
USA
Old November 23rd 04, 07:44 PM
Eric Greenwell
Eric Greenwell
Washington State
USA
Problems tuning nav radios cm Simulators 0 January 4th 05 12:29 AM
Tanis Pre-heater with Engine Analyzer O. Sami Saydjari Owning 12 January 29th 04 12:50 PM
Tuning up FS9 Dan Moos Simulators 3 September 14th 03 09:18 PM
Tuning In and Hot Take-Offs Art Cline Rotorcraft 0 July 28th 03 12:32 PM
