Flarm suppression of ADS-B out on Tow Planes
Old March 19th 19, 08:54 PM posted to rec.aviation.soaring
Default Flarm suppression of ADS-B out on Tow Planes
For those towing behind tow planes equipped with ADS-B out (1090MHz), a new version of PowerFlarm firmware 6.67 is now available which should suppress the collision warning from the tow plane's ADS-B out. Below are release notes.
Version 6.67
Published 04 March 2019
Platforms Build Expiration
All PowerFLARM- and Classic FLARM-based devices a072808ac
Not operational after 31 October 2020
Changes since 6.63 Enhancements
ï‚¡ PowerFLARM: Suppress warnings from tow aircraft equipped with ADS-B Out, but not FLARM
ï‚¡ All: Info Alarms/traffic advisories in saturated situations are moderated such that they can no longer be mistaken as full traffic alarms
Thanks to Jerome at Flarm for working on providing this enhancement.
GC
Old March 19th 19, 09:32 PM posted to rec.aviation.soaring
JS[_5_]
Version 6.67
GC
Thanks, just updated. The display shows v6.67, took 5 minutes.
Looking forward to trying that.
Old March 19th 19, 10:50 PM posted to rec.aviation.soaring
What about those tow planes equipped with ADS-B out using UAT (978MHz)?
Old March 19th 19, 11:10 PM posted to rec.aviation.soaring
Ramy[_2_]
UAT is not showing in powerflarm anyway.
This is great news. I am curious how the new suppression determine the ADSB signal is from the tow plane. I guess the suppression will work similarly for any formation flying, which is a good thing.
Ramy
Old March 20th 19, 01:44 AM posted to rec.aviation.soaring
Mike Schumann[_2_]
PF doesn't receive 978 MHz, so there shouldn't be alarms generated.
Jeez is there anybody who has not been paying attention who actually has equipped a tow plane with UAT Out?
skyBeacon is a pretty darn inexpensive and easy to implement way to make a tow plane 2020 compliant. I wouldn't be surprised if a significant number of people don't go that route, even though it is UAT instead of 1090ES.
A big question is exactly how FLARM has suppressed the tow plane ADS-B alarms. Does FLARM recognize the fact that the tow plane and glider are in formation, and only suppress the alarm while the formation flight continues, or does it somehow completely suppress all alarms for the tow plane? You definitely would want to see tow plane alarms after the glider releases from the tow in the event that you accidentally get on a collision course with the tow plane after the completion of the tow.
Old March 20th 19, 03:29 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
These seem to me to be two examples of difficulty assessing the number of decimal places in looking at probabilities.
Equipping a towplane with UAT says an owner is willing to spend money on ADS-B, but not the flavor that represents the vast majority of collision threats (it's a glider towplane after all). That just seems dopey. UAT is problematic for other reasons too in that it requires ADS-R or a dual-band receiver to be seen by the vast majority of aircraft that have opted for 1090ES and towplanes tend to operate down low where ADS-R services may not be available for other powered traffic. A waste of money that simultaneously makes other people's lives less safe and more difficult. Buying something that's far less likely to work because it's cheap hardly seems like a smart buy.
I doubt that Flarm would pick an algorithm that can both identify what's a towplane through formation flight and then blank out the ADS-B ICAO address and never check for towplane behavior again - but even if it did the probability of a towplane releasing a glider and circling around in a climb to become a collision threat seems like and extremely low probability scenario and not a reason to reject/critique the idea of towplane suppression. In 46 years of glider flying I've never, ever seen a towplane do that. Either way towplane suppression is a good idea and I tend to think the Flarm folks are pretty clever. I look forward to trying it out.
Andy Blackburn
Old March 20th 19, 03:46 AM posted to rec.aviation.soaring
Darryl Ramm
That would be the stupidest thing in the world. "significant number".... bull****. There are very few towplanes anywhere that I know of that are planning to equip with ADS-B Out for 2020 compliance reasons. I'm not aware of any of them going UAT, I had one question asked months ago and that person went away understanding why to use 1090ES Out not UAT. I only hear about ADS-B Out installs that folks ask for help with, but by now I'd hope that enough people know to keep UAT away from PowerFLARM equipped gliders.
Old March 20th 19, 03:59 AM posted to rec.aviation.soaring
Ramy[_2_]
Andy, I know of two mid airs between a tow plane and the glider it just released. One luckily just exchanged some paint, the other was fatal to both pilots. So I would hope and expect the suppression is only during the tow.
Ramy
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Flarm IGC files on non-IGC certified Flarm? Movses Soaring 21 March 16th 15 09:59 PM
Military Suppression of Enemy Air Defenses (SEAD): Assessing Future Needs Mike Naval Aviation 0 December 12th 05 04:35 PM
