Angaar
At 08:00 28 November 2004, Tanel wrote:
Palju sellise asja ehitamine vőiks maksta? http://www.portmoak.force9.co.uk/new...os_3.htm#entry I don't know what the comment about the new Portmoak 'glider store' means but there are also 2 earlier series of construction photos on the Scottish Gliding Centre website ...._photos_2.htm and ....._photos_1.htm http://www.portmoak.force9.co.uk/introduction.htm#entry We think there is unlikely to be a hangar with a significantly higher storage density. John Galloway |
"John Galloway" wrote in message ... At 08:00 28 November 2004, Tanel wrote: Palju sellise asja ehitamine vőiks maksta? http://www.portmoak.force9.co.uk/new...os_3.htm#entry I don't know what the comment about the new Portmoak 'glider store' means but there are also 2 earlier series of construction photos on the Scottish Gliding Centre website ...._photos_2.htm and ....._photos_1.htm http://www.portmoak.force9.co.uk/introduction.htm#entry We think there is unlikely to be a hangar with a significantly higher storage density. John Galloway The 'Cape Hangars' in Worcester South Africa used the same design perhaps 15 or more years ago. In addition to the bottom row of gliders a number of Libelles and other light ships were hoisted into the roof which was a little higher than the portmoak 'pretender'. :-) Ian |
At 21:00 28 November 2004, Tango4 wrote:
'John Galloway' wrote in message ... At 08:00 28 November 2004, Tanel wrote: Palju sellise asja ehitamine vőiks maksta? http://www.portmoak.force9.co.uk/new...os_3.htm#entry I don't know what the comment about the new Portmoak 'glider store' means but there are also 2 earlier series of construction photos on the Scottish Gliding Centre website ...._photos_2.htm and ....._photos_1.htm http://www.portmoak.force9.co.uk/introduction.htm#entry We think there is unlikely to be a hangar with a significantly higher storage density. John Galloway The 'Cape Hangars' in Worcester South Africa used the same design perhaps 15 or more years ago. In addition to the bottom row of gliders a number of Libelles and other light ships were hoisted into the roof which was a little higher than the portmoak 'pretender'. :-) Ian It doesn't 'pretend' to be a first - in fact the Bristol and Gloucestershire (Nympsfield) South hangar designed by the late Tony Pentelow a lot longer ago than 15 years was the basis for the Portmoak design. John Galloway |
http://www.portmoak.force9.co.uk/introduction.htm#entry We think there is unlikely to be a hangar with a significantly higher storage density. John Galloway Not with private direct entrance/exit for every glider, anyhow. I consider the construction as the traditional glider hangar. Ordinary large halls (maybe with doors on both ends) can be packed equally dense, maybe even more, but getting only the last/midmost glider out is painfull. I didn't found any ratios describing gliders per area or ?'s per glider, did anyone else..? js |
This design looks a lot like what we have had at Sunflower Gliderport
for just over 30 years. Except ours has 10 rolling doors on each side. Roughly 200 feet long, and 40 feet deep. Currently has 1-26, IS-29 Lark, HP-14, 2-33, and G-103 on one side, empty space where a Woodstock lived, 2-22, C-182 (Towplane), empty space where Slingsby Swallow will soon return, 16.5 meter Diamant, and another G-103 on the other side. Total of 11 planes. Would be tought to fit an Eta in with all the panels on, but other that... We keep the wing on the ground with an old tire or similar thing. Padding at the option of the owner. It is also tall enough we could hoist another over some of the less tall gliders. It actually tall enough for a Cessna 310 with a flat nose strut, I think. Somewhere around 13 to 14 foot high doors. When it was built, we could lock it. Trouble is, as it seems with any club, someone will show up to fly and not have their key. It goes down hil from there. Just like the storage cabinet we made. Put a lock on it. Even wrote the combo on the back of the box in pencil. The instructor came up, needed into the box, so he "openned the box without removing the lock". A couple of recommendations for you. It is a long ways from the upright of the truss to the outside of the roof. Suggest you put cables and over center boomers to tie the edge of the roof to the ground. Done on both sides, the roof will no longer flex in the wind. This is a simple affair, of two cable loops. One attached to the roof, the other attached to the ground. Use the boomer/latch/hasp to connect the cables and apply tension. Recommend one at every truss, except of course, for the end walls. Teach everyone to set the latch on the ground when they remove it, so it cannot ding the wing of the sailplane being removed. Might want to make the upper cable loops shorter so they will not hang down hear the wings. Put a vertical post hanging down from the roof, just inside of the doors, every 1/3 of a door span. This way, if the roof does flex in a wind storm, the doors cannot fall in on the sailplanes they are protecting. We learned all these lessons the hard way. Our doors roll on tracks on the ground and have a simple pin going into a c-channel at the top. My favorite scary memory of this hangar was watching a door just fall outward, right next to a glider. The door was being moved, and all the top pins fell out. The door was claer of the glider, and just made a lot of wind and dust fly. We propped the door back up, put in new pins, put the glider away for the evening, and went on our way. A beautiful design and a great way to store sailplane. Steve Leonard Wichita, KS |
The ultimate in inefficiancy must be the T4 hanger at Lasham. A great big
hanger with one end blocked off so gliders can only be loaded at the other. Tough luck if yours is right at the back. Remove 25 + gliders, remove yours, replace 25+ gliders. A recipe for hanger rash if I ever saw one |
I tried to post this link into an estonian newsgroup, but sent it
accidentaly here. We need a cheap hangar for 10 gligers and any good ideas or fotos are welcome. Tanel |
