Looking for Tost Standard Drum Brake Wheel (USA)
Old March 27th 19, 11:42 PM posted to rec.aviation.soaring
Default Looking for Tost Standard Drum Brake Wheel (USA)
Need Tost Standard Drum Brake Wheel that fits a 5.00 -5 tire. This will go on a DG400. Looks like it is standard on several other gliders.
The Spec are 125 x 20 for the bearing.
Changed my brake pads and found out the drum material has some cracks.
Looking for new or used but good shape.
One not available at W&W or other vendors at present
Thanks
Kevin Anderson
Old March 28th 19, 01:19 AM posted to rec.aviation.soaring
Bob Kuykendall
On Wednesday, March 27, 2019 at 4:42:29 PM UTC-7, wrote:
Need Tost Standard Drum Brake Wheel that fits a 5.00 -5 tire...
We've seen these cracks in several Tost 5" wheels, so it might be hard to find a used but uncracked wheel half.
If your DG is licensed Experimental, we can set you up with a Matco disk brake unit that's much more effective than the Tost.
--Bob K.
Old March 28th 19, 12:11 PM posted to rec.aviation.soaring
Sounds interesting and I would like to explore some more. I emailed you my contact info. Please email yours and I will get in touch later today.
Have you converted a DG400 and how involved is the conversion?
Others might be interested in the details also.
Thanks
Kevin
Standard Jantar wheel brake assembly [email protected] Soaring 9 April 6th 19 02:34 AM
Tost 5“Penta disk brake wheel Mod for Duo Discus Mike I Green Soaring 0 February 6th 12 09:38 PM
FS Cobra brake drum w/new bearing Hartley Falbaum[_2_] Soaring 1 December 3rd 11 01:05 PM
2-33 brake drum [email protected] Soaring 2 June 9th 07 02:22 AM
Glider Drum Brake Rebuild [email protected] Soaring 4 January 17th 06 09:39 PM
