WX Block life?
Old April 7th 19, 02:45 PM posted to rec.aviation.soaring
Default WX Block life?
Is there a limit to how old unused WX Block should be kept? I use a bit over half doing a full polish/seal/coat on my Pegasus. Since I only do the shiny-up work every couple of years due to general laziness, I'd like to use the leftover stuff to avoid wasting it (and save some money.) I keep it where it won't freeze as that is specifically warned against on the label. And is it a good/bad idea to use something like Mother's Gold Carnauba wax over the WX Block?
Old April 8th 19, 12:44 PM posted to rec.aviation.soaring
Sean Franke
I have used the same bottle of WX Block year after year. It's still good when you see original consistency after shaking the contents. Use WX SpeedCoat over WX Block for a quick refresh which uses the same high-quality UV inhibitors. Other products have limited or non-existent UV protection.
Sean Franke
Need WX BLOCK & WX SEAL Bill G Soaring 0 July 6th 17 12:06 AM
Does Wx/Block work ? glider[_2_] Soaring 6 March 26th 10 11:57 PM
Block out someone? (Little Hitler) Jeff Military Aviation 6 April 13th 04 07:03 PM
Block Allocation? AES/newspost Piloting 23 February 12th 04 06:58 AM
More Info on Block 52 F-16 robert arndt Military Aviation 0 November 18th 03 03:07 PM
