https://en.wikipedia.org/wiki/De_Hav...DHC-1_Chipmunk
The de Havilland Canada DHC-1 Chipmunk is a tandem, two-seat, single-engined primary trainer aircraft developed and manufactured by Canadian aircraft manufacturer de Havilland Canada. It was developed shortly after the Second World War and sold heavily throughout the immediate post-war years, being typically employed as a replacement for the de Havilland Tiger Moth biplane. The Chipmunk holds the distinction of being the first postwar aviation project conducted by de Havilland Canada. It performed its maiden flight on 22 May 1946 and was introduced to operational service that same year. During the late 1940s and 1950s, the Chipmunk was procured in large numbers by military air services such as the Royal Canadian Air Force (RCAF), Royal Air Force (RAF), and several other nations' air forces, where it was often utilised as their standard primary trainer aircraft. The type was also produced under licence by de Havilland in the United Kingdom, who would produce the vast majority of Chipmunks, as well as by OGMA (Oficinas Gerais de Material Aeronáutico) in Portugal. The type was slowly phased out of service from the late 1950s onwards, although in the ab initio basic training role, this did not occur within the Royal Air Force until 1996, having finally been replaced by the Scottish Aviation Bulldog. However, many of the Chipmunks that had been formerly in military use were sold on to civilians, either to private owners or to companies, where they were typically used for a variety of purposes, often involving the type's excellent flying characteristics and its capability for aerobatic manoeuvres. More than 70 years after the type having first entered service, hundreds of Chipmunks remained airworthy and were in operation around the world. Role Trainer Manufacturer de Havilland Canada Designer Wsiewolod Jakimiuk First flight 22 May 1946 Introduction 1946 Retired 1972 (Canada) Status Out of production, in active service Primary users Royal Air Force Royal Canadian Air Force Portuguese Air Force Belgian Air Force Produced 1947–1956 Number built 1,284 (including Canadian, British, and Portuguese production) The de Havilland Canada DHC-1 Chipmunk is a two-seat, single-engine aircraft that has been heavily used as a primary trainer aircraft. The basic configuration of the aircraft included a low-mounted wing and a two-place tandem cockpit, which was fitted with a clear perspex canopy covers the pilot/student (front) and instructor/passenger (rear) positions and provided all-round visibility. The Chipmunk uses a conventional tailwheel landing gear arrangement and is fitted with fabric-covered flight control surfaces; the wing is also fabric-covered aft of the spar. In terms of handling, the Chipmunk exhibited a gentle and responsive flight attitude. Early production aircraft were only semi-aerobatic, while later production models were almost all fully aerobatic. The structure of the Chipmunk makes heavy use of metal, the majority of the airframe being composed of a stress-skinned alloy; this allowed the adoption of thinner wings and consequently provided for increased performance as well as a greater degree of durability. Numerous features were incorporated in order for the type to better perform in its trainer role, including hand-operated single-slotted wing flaps, anti-spin strakes, disc brakes on the wheeled undercarriage, a thin propeller composed of a solid lightweight alloy, the adoption of an engine-driven vacuum pump in place of external venturi tubes to power cockpit instrumentation, electric and Coffman cartridge engine starters as alternative options, cockpit lighting, onboard radio system, and an external identification light underneath the starboard wing. The Royal Air Force (RAF) had been one of the operators to quickly take notice of the new Canadian trainer, and encouraged its formal evaluation with an eye towards procuring it. Accordingly, a total of three Chipmunk aircraft were transported to the United Kingdom, where they underwent an evaluation by the Aeroplane and Armament Experimental Establishment (A&AEE) at RAF Boscombe Down, Wiltshire. Based upon this favourable evaluation, the British Air Ministry proceeded to formulate and release Air Ministry specification T.8/48 around the type as a replacement for the de Havilland Tiger Moth biplane then in use. This specification was also contested by the rival Fairey Primer, which lost out to the Chipmunk and ultimately did not enter production. As such, the fully aerobatic Chipmunk was ordered to serve as an ab initio trainer for new pilots. The RAF received a total of 735 Chipmunks, which were designated in British service as the de Havilland Chipmunk T.10; these aircraft had been manufactured in the United Kingdom by de Havilland, the parent company of de Havilland Canada. Specifications (DHC-1 Chipmunk) General characteristics Crew: 2, student & instructor Length: 25 ft 5 in (7.75 m) Wingspan: 34 ft 4 in (10.47 m) Height: 7 ft in (2.1 m) Wing area: 172 ft² (16.0 m²) Empty weight: 1,517 lb (646 kg) Loaded weight: 2,014 lb (953 kg) Max. takeoff weight: 2,200 lb (998 kg) Powerplant: 1 × de Havilland Gipsy Major 1C, 145 hp (108 kW) Performance Maximum speed: 120 kn, 138 mph at sea level (140 mph is also given) (222 km/h) Cruise speed: 90 kn Range: 225 NM (445 km) Service ceiling: 15,800 ft (5200 m) Rate of climb: 900 ft/min (274 m/min) Wing loading: 11.709 lb/ft² (57.82 kg/m²) Power/mass: .072 hp/lb (.113 kW/kg) * |
| Thread Tools | |
| Display Modes | |
| de Havilland Canada DHC-5 Buffalo pics 2 [03/11] - de Havilland Canada DHC-5 Buffalo cockpit.jpg (1/1) | Miloch | Aviation Photos | 0 | November 4th 17 03:57 PM |
| de Havilland Canada DHC-5 Buffalo pics 2 [02/11] - de Havilland Canada DHC-5 Buffalo 76954452.jpg (1/1) | Miloch | Aviation Photos | 0 | November 4th 17 03:57 PM |
| de Havilland Canada DHC-5 Buffalo pics 2 [01/11] - de Havilland Canada DHC-5 Buffalo 1219874-v20-16.jpg (1/1) | Miloch | Aviation Photos | 0 | November 4th 17 03:57 PM |
| de Havilland Canada DHC-5 Buffalo pics 1 [09/12] - de Havilland Canada DHC-5 Buffalo 0621194.jpg (1/1) | Miloch | Aviation Photos | 0 | November 4th 17 03:55 PM |
| Royal Malaysian Air Force MuseumG] [21/22] - de Havilland Canada DHC.1 Chipmunk DSC_0241.jpg (1/1) | Indrek[_6_] | Aviation Photos | 0 | September 16th 12 02:55 AM |
