https://en.wikipedia.org/wiki/Loening_OL
The Loening OL, also known as the Loening Amphibian, was an American two-seat amphibious biplane built by Loening for the United States Army Air Corps and the United States Navy. First flown in 1923, the OL was a high-performance amphibian with a large single hull and stabilizing floats fitted underneath each lower wing. The landing gear was retractable by use of a hand crank in the cockpit, and the plane was equipped with a tailskid for operations on land. It had a tandem open cockpit for a crew of two. The aircraft could be flown from either cockpit, with a wheel control in the forward cockpit and a removable stick control in the rear. Navigation and engine instruments were located in the forward cockpit. The hull was built of Duralumin on a wooden frame, with five watertight compartments connected through a selector switch to a bilge pump in the rear cockpit. Plugs in the bottom of each compartment permitted drainage on the ground. The fuselage was constructed on top of the hull. The aircraft was strength-tested at Columbia University. Role Amphibious observation aircraft Manufacturer Loening First flight 1923 Primary users United States Navy United States Army Air Corps Number built 165 The United States Army Air Corps ordered four prototypes as the XCOA-1, powered by a 400-hp Liberty V-1650-1 engine mounted inverted for clearance of the three-bladed variable-pitch steel propeller. The engine came with a fire suppression sprinkler system and was encased in a streamlined cowling to protect it from sea spray. Oil from a tank in the fuselage was cooled by passing through a spiral copper tube exposed to the slipstream on top of the cowling. The fuel tanks were mounted inside the hull, with a 140-gallon (530-liter) gasoline tank under the wings, and a reserve 60-gallon (230-liter) gasoline-benzol tank between the cockpits. Total fuel capacity provided for roughly ten hours of flight. A number of variants were introduced for both the Army and the Navy. During later production, the company merged with the Keystone Aircraft Corporation. Specifications (OL-9) General characteristics Crew: two (Naval ver had three) Length: 34 ft 9 in (10.59 m) Wingspan: 45 ft 0 in (13.72 m) Height: 12 ft 9 in (3.89 m) Wing area: 504 ft2 (46.82 m2) Empty weight: 3649 lb (1655 kg) Gross weight: 5404 lb (2451 kg) Powerplant: 1 × Pratt & Whitney R-1340-4 Wasp radial piston engine, 450 hp (336 kW) Performance Maximum speed: 122 mph (196 km/h) Range: 625 miles (1006 km) Service ceiling: 14,300 ft (4360 m) * |
| Thread Tools | |
| Display Modes | |
| Pushers, pt 5 - Loening Air Yacht.jpg (1/1) | Mitchell Holman[_9_] | Aviation Photos | 0 | March 5th 18 02:27 PM |
| Udvar hazy Batch 4 [53/53] - Loening 0A-1A DSC_3974.jpg (1/1) | Indrek[_6_] | Aviation Photos | 0 | November 16th 15 05:21 PM |
| Udvar hazy Batch 4 [52/53] - Loening 0A-1A DSC_3970.jpg (1/1) | Indrek[_6_] | Aviation Photos | 0 | November 16th 15 05:21 PM |
| Loening Air Yacht | Byker | Aviation Photos | 0 | August 3rd 15 10:12 PM |
| Ugly Airplanes, pt7 - loening.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | March 3rd 08 02:21 PM |
