Taurus glider for sale
Old April 17th 19, 09:08 AM posted to rec.aviation.soaring
Default Taurus glider for sale
In the Wings and Wheels classified ads there is listed a Taurus selflaunch glider for sale.
Originally it was N797SD, sn 107T503LSA. Currently carrying a different N number and serial number, but it is the same glider.
This Taurus was involved in a hangar fire about 4 years ago in Memphis, Tn. While the flames did not reach the glider temperatures were high enough to melt the canopy Plexiglas. That is a temperature of about 325 F.
The manufacturer, Pipistrel d.o.o of Ajdovscina, Slovenia has declared this glider un-airworthy and will provide no customer support. They are shocked that it has not been destroyed and is now considered safe for flight.
Caveat Emptor
Robert Mudd Pipistrel dealer and service center.
Old April 17th 19, 03:25 PM posted to rec.aviation.soaring
In the past haven't some people paid a manufacturer for "twice baked" wings to reduce spar shrinkage?....
This one just had it done fully assembled...
Old April 17th 19, 04:40 PM posted to rec.aviation.soaring
Scott Williams
Caveat Emptor
insert 'represented' instead of "considered"?
Old April 18th 19, 05:09 AM posted to rec.aviation.soaring
AS
Caveat Emptor
I get the 'different N-Number' part but how can one change the serial number of an aircraft??
Uli
'AS'
Old April 18th 19, 05:57 AM posted to rec.aviation.soaring
Ross[_3_]
That is easy enough. Ask the guys that fly the Duo Discus with the serial number SS01 in a far away country
Old April 18th 19, 07:01 PM posted to rec.aviation.soaring
Bob Kuykendall
On Wednesday, April 17, 2019 at 1:08:53 AM UTC-7, wrote:
Originally it was N797SD, sn 107T503LSA. Currently carrying a different N number and serial number...
Searching the FAA database on the N-number in the ad, I see that it reports the exact serial number you cite. So that record is straight.
As for the ad reporting the serial number as 177, that could be a simple typo on 107, which is likely the part of the serial number that represents the aircraft's position in the production sequence.
--Bob K.
Old April 18th 19, 07:22 PM posted to rec.aviation.soaring
AS
--Bob K.
That makes sense - thanks, Bob!
On my glider, the serial numbers of the fuselage, three wings and tail are all different and got put together under A/C serial # 228.
Uli
'AS'
Old April 19th 19, 04:49 AM posted to rec.aviation.soaring
--Bob K.
Uli
'AS'
Uli, but I believe the registration is based on your fuselage SN# . I have documents for a Libelle where the original fuselage was damaged and was swapped out with an earlier fuselage (earlier construction technique use with less glass)and the repair station swapped out the SN# placard with the later fuselage.. Now that was just wrong!
Old April 19th 19, 06:09 AM posted to rec.aviation.soaring
Echo
Wouldn't it be convenient for a manufacturer to avoid servicing or any other obligations by simply "declaring it unairworthy" without seeing it?
Have you seen it in person?
Pipistrel Taurus: Club Glider? Phil Chidekel Soaring 3 February 29th 16 04:05 AM
Glider equipment for sale Roger Fowler[_3_] Soaring 0 August 2nd 14 06:05 PM
GLIDER 4 SALE BobD Soaring 0 March 16th 14 08:45 PM
Glider for Sale 5 ugly Soaring 1 December 8th 13 12:57 AM
Taurus Glider Ready for Flight Tests Michael Coates Soaring 5 April 5th 04 04:05 AM
