Cobra trailer tongue.
Old April 28th 19, 06:24 PM posted to rec.aviation.soaring
Bryce Sammeter
Default Cobra trailer tongue.
I know its a snowballs chance in hell, but I'd be doing myself a disservice by not at least asking. Does anyone have a damaged cobra trailer with a good usuable tongue laying around?
Bryce
480-760-5610
Old April 28th 19, 08:28 PM posted to rec.aviation.soaring
JS[_5_]
Bryce
480-760-5610
https://wingsandwheels.com/cobra-tra...-1-seater.html
Been there.
The square one is stronger than the round one, which I'm guessing is the type found cracked. A used round one from a damaged trailer may already be damaged.
Old April 28th 19, 09:41 PM posted to rec.aviation.soaring
Bryce Sammeter
Ya I should of specified Im looking for the square style, or even just the square overrun bolted to the tongue. Just trying my luck before I plunk down an arm and a leg.
Old April 28th 19, 09:51 PM posted to rec.aviation.soaring
Ross[_3_]
Can you post me a pic of what you need??
Cheers
Old April 28th 19, 10:12 PM posted to rec.aviation.soaring
Bryce Sammeter
Can't seem to post pics directly to the forum, Sent you a private message.
Old April 29th 19, 02:30 PM posted to rec.aviation.soaring
I am not a qualified mechanical engineer to tell you it would carry the load but I would think that you could buy what you need at any steel supply house knowing the length and width/height plus, importantly, the wall thickness. Best of luck, John (OHM)
Old April 30th 19, 04:53 AM posted to rec.aviation.soaring
bumper[_4_]
On Monday, April 29, 2019 at 6:31:00 AM UTC-7, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
A piece of cake, really. If you don't happen to have metal working and welding equipment, any good shop should be able to put it together. A galvanizing place may be harder to find. If you prime and paint instead, suggest etching the steel with dilute phosphoric acid before painting. Jasco Metal Prep is available at many hardware stores or paint supply places. Paint it on, hose it off.
Old May 2nd 19, 09:29 PM posted to rec.aviation.soaring
Thinking a little further on this, the square tube is bound to be a metric size. Getting an equivalent SAE sized tube may involve some effort. Slightly larger might not fit the internal brackets (or the AL-KO coupler). The better option is slightly smaller which will need some (welded on) thin shims to take up the slack - which the welding shop can handle (along with cutting off and reattaching the old jockey wheel bracket and underside's V shaped stand).
John OHM Ω
Old May 3rd 19, 12:13 AM posted to rec.aviation.soaring
I have built about 35 sailplane trailers (before giving up on them as anything but a way to delay starvation) and have worked on a number of others, including Cobra, Komet, Eberle and any number of homebuilts. If you just want to replace the tongue (or Drawbar as it is sometimes called), you need to ask yourself a couple of questions:
"Do I want the basic square tube with a hitch only?" If so, go ahead and have a welding shop fabricate the thing. No problem with dealing with the simplified design.
If the question is, "Can I duplicate the AL-KO drawbar, including the surge brake mechanism, telescoping tongue, parking brake and jockey wheel mount? I am willing to bet that the efforts of a welding shop that could do it will end up being MUCH more expensive than just ordering one from Wings and Wheels. (Price on the drawbar with everything except the jockey wheel is $619.) With an average labor rate of $65/hour or more at many welding shops, the cost will most likely be a lot higher when you factor in the fabrication of all of the components. Remember the levers, damper brackets, sliding bushings, grease fittings, hitch, protective boot, surge damper, linkages and so on. This is not a trivial job.
As a matter of fact, the $619 is less than I expected, and I may replace the round tube on my 1981 Cobra with a new one. I certainly can't duplicate it for that!
Old May 3rd 19, 12:24 AM posted to rec.aviation.soaring
AS
On Thursday, May 2, 2019 at 4:29:14 PM UTC-4, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
John OHM Ω
The current, square tube tow bar design (metric or imperial sized) can be improved by a lot. The hitch of a Cobra trainer is bolted on by two M12 bolts. The entire assembly is essentially coupled by friction. These bolts are not supposed to be in shear. Anyhow, one of the big draw-backs of square tubing is that the walls start to cave in when the bolts are being torqued.
Many moons ago, I did replace the rusted out tow bar of my trailer. I bought an equivalent stainless tube and drilled the holes for the hitch slightly larger than needed. Make sure not to drill through the tube's weld flash but 90* to it. Then I inserted short, tight fitting pieces of thick-walled SS-pipe trough the open end until they were aligned with the holes I drilled and TIG-welded them in place. Now I could torque the bolts holding the hitch to their appropriate value without deforming the square tubing.
Uli
'AS'
Cobra Tongue Bellows [email protected] Soaring 5 May 23rd 19 08:15 PM
Al-Ko Trailer Tongue failure Dave Springford Soaring 89 March 5th 18 11:04 PM
Replacement for a Cobra Tongue [email protected] Soaring 7 May 20th 08 09:25 PM
US source for wheel on the tongue of Cobra trailer? Mark Zivley Soaring 3 January 18th 05 03:51 AM
Cobra Tongue Strut Removed Finally Brian Iten Soaring 0 December 4th 04 07:54 PM
