When to apply gap seal tape
Old May 7th 19, 10:56 PM posted to rec.aviation.soaring
soaringjac
Default When to apply gap seal tape
I am going to be using 3M perfect it followed by WX Block/Seal. Just wondering when in the process i should apply the new gap seals? I think i read that the seals/tape does not stick too well to freshly WX block/sealed surfaces. Should i put them on now and then mask them off, and then do the whole 3M/WX block seal process?
Old May 7th 19, 11:38 PM posted to rec.aviation.soaring
Others will be better than I, but to me, do all sanding and machine polish, clean place for seals and "safety tape", apply said items, then finish.
Just be careful around tape edges.
Old May 8th 19, 01:18 AM posted to rec.aviation.soaring
Bob Youngblood
You will get many opinions here, do what works for you! As for myself I do my waxing and clean the entire tape edge with a good cleaner such as acetone, or other high evaporating cleaner. Then apply the tape, it works for me.
Old May 8th 19, 04:01 AM posted to rec.aviation.soaring
soaringjac
On Tuesday, May 7, 2019 at 2:38:11 PM UTC-7, Charlie M. (UH & 002 owner/pilot) wrote:
Thanks Charlie! I am thinking im going to do the 3M stuff first, then clean where the tape goes and apply the tape. After that i will do the WX stuff and mask off the seals so they don't get ruined when i apply the WX block.
Old May 8th 19, 04:02 AM posted to rec.aviation.soaring
soaringjac
Thanks Bob!
Solvent for Gap-Seal tape prep AS Soaring 15 August 15th 17 04:54 PM
LS4 aileron gap seal and mylar seal width Eric Foertsch Soaring 8 May 18th 17 08:50 PM
Does part 91 apply outside the USA? Barry Piloting 1 February 5th 08 10:58 AM
Does part 91 apply outside the USA? Barry Piloting 1 February 5th 08 02:48 AM
Teflon gap seal tape... Marc Ramsey Soaring 10 April 3rd 05 05:35 PM
