Dittel FSG50 squelch
Old May 8th 19, 06:16 PM posted to rec.aviation.soaring
Hartley Falbaum[_2_]
Default Dittel FSG50 squelch
I am seeking the ability to adjust the squelch on our club's G102. I have info on the location of the pot for a FSG71m/70, but not the FSG50/60. Recently it is breaking squelch full time. I have searched for stray RF, and not found any. Of course, it could be a more serious problem, but the radio is not worth the cost to send to Penninsula for a checkup. If adjustment doesn't do it, it gets replaced.
I don't have a schematic, and I don't have a VHF signal generator. Just want to tweak it by ear.
So a diagram showing the location of the pot would be much appreciated.
Thanks in advance
Hartley Falbaum
hfalbaum . at. comcast.c0m
Old May 8th 19, 07:02 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
i=
Recen=
not=
is=
does=
wan=
Thanks in advance
Hartley Falbaum
PM sent.
Old May 9th 19, 02:54 AM posted to rec.aviation.soaring
AS
Thanks in advance
Hartley Falbaum
Hartley,
if it turns out that the magic smoke has left the radio and you can't put it back in, check he
https://www.segelflug.de/osclass/ind...=item&id=34122
This guy has 2 of them for sale. They can't be too expensive since they are virtually worthless over there.
Just pointing out an option....
Uli
'AS'
Old May 9th 19, 12:24 PM posted to rec.aviation.soaring
Thanks in advance
Hartley Falbaum
Old May 9th 19, 12:25 PM posted to rec.aviation.soaring
Thanks in advance
Hartley Falbaum
Information obtained--Many thanks!
Old May 10th 19, 02:55 PM posted to rec.aviation.soaring
Please share.
Many of us with the same radio, same problem.
Old May 10th 19, 04:12 PM posted to rec.aviation.soaring
At 13:55 10 May 2019, wrote:
Please share.
Sure,
www.newportpeace.co.uk/temp/fsg50 squelch.pdf
Tim.
Old May 10th 19, 05:15 PM posted to rec.aviation.soaring
Dan Daly[_2_]
On Friday, May 10, 2019 at 11:15:05 AM UTC-4, Tim Newport-Peace wrote:
At 13:55 10 May 2019, jeff wrote:
Please share.
Sure, www.newportpeace.co.uk/temp/fsg50 squelch.pdf
Tim.
Thanks for making it available!
Old May 10th 19, 07:00 PM posted to rec.aviation.soaring
Knowing how much to turn the pot is the issue, I had a close friend, who is a electrical engineer for Cobham helicopter radio guys, use a a set from work to adjust the squelch to the proper design specs. But guessing and trying works too if it is an easy install/removal from the glider or a bench test is possible. I also bought one from europe so now have a spare.
CH
Old May 10th 19, 07:15 PM posted to rec.aviation.soaring
Thanks in advance
Hartley Falbaum
This worked well for FSG71M and the FSG50
About 25 degrees counterclockwise did it for us.
I have an oscilloscope, but no VHF signal generator. I don't know precisely how much attenuation I did, but it seems to work.
Dittel radio squelch [email protected] Soaring 42 October 7th 16 04:31 PM
Dittel FSG 60M....Where is the internal Squelch adjustment pot? vtcyclist Soaring 1 September 20th 16 01:28 AM
Dittel FSG50 schematics wanted Georg Holderied[_3_] Soaring 2 June 4th 13 12:50 AM
Dittel FSG50 PTT circuit Chris Davison Soaring 0 October 23rd 03 06:29 PM
Dittel FSG50 wiring diagram Chris Davison Soaring 0 October 15th 03 07:23 AM
