Trailering a Glider through Canada
Old May 8th 19, 08:11 PM posted to rec.aviation.soaring
Mike Reid
Default Trailering a Glider through Canada
A permanent Registration Certificate is required to fly a US registered aircraft in Canada. Anyone know if a glider can be trailered through Canada with only a temporary Registration Certificate?
Old May 8th 19, 10:31 PM posted to rec.aviation.soaring
George Haeh
As long as your trailer has a state registration / title and plate to match, I see no problem.
If not, you need to get that paperwork and plate in order.
Canada Customs did check my plate against the VIN the last time I did an import. You may be next.
Importing a Glider from Canada to US GeneReinecke Soaring 17 March 1st 15 09:35 PM
Buying a glider from Canada Bmwbob Soaring 1 August 6th 10 11:20 PM
Importing a glider from Canada to US Sam Discusflyer Soaring 2 December 12th 06 09:28 PM
Importing a glider from Canada to US Sam Discusflyer Soaring 0 December 12th 06 02:53 PM
Selling glider US - Canada John C Soaring 5 July 6th 06 11:22 PM
