Astir CS repair manual
Old January 11th 05, 04:54 PM
Default Astir CS repair manual
Our gliding club owns an Astir CS sailplane and am in need of a repair
manual.
If none are available has anyone had any need to repair/refinish the
trailing edge of the ailerons which tend to drag on the graound after
landing.
Also, does anyone know of a source for a landing gear handle grip for
same? Any salvage gliders out there?
Any help appreciated.
Old January 11th 05, 05:13 PM
Bob K.
I've found control handle grips identical to those supplied on European
sailplanes by digging through the pile of bent and broken poles at the
rental shop of the local ski resort. Doesn't work in every case, but it
has worked for some.
Thanks, and best regards
Bob K.
http://www.hpaircraft.com
Old January 11th 05, 06:20 PM
John Sinclair
Three layers of 92110 laid on the diaginal will do
the trick. Fill and finish with Ultra-lite, primer
& Prestec. Check W/B of any control surface after repair.
JJ
in need of a repair
manual.
the graound after
landing.
handle grip for
astir cs 77 maintenance manual pete83 Soaring 1 January 6th 05 05:46 PM
LX1000 Manual & Speed Astir Manual Avron Tal Soaring 1 June 20th 04 07:15 AM
Grob Twin Astir 1 Manual / Flughandbuch Sebastian Schroeter Soaring 2 June 14th 04 11:41 AM
PBJ-1(Navy mitchell) manual and bunch of ac. manuals FS Nenad Miklusev Naval Aviation 0 April 23rd 04 09:08 PM
Polikarpov PO-2 manual FS,books & Resin kits FS Nenad Miklusev General Aviation 0 April 23rd 04 09:07 PM
