Rudder pedal S-tubes
Old May 11th 19, 04:14 PM posted to rec.aviation.soaring
jp
Default Rudder pedal S-tubes
What is the purpose of S-tubes on rudder pedals?
Old May 11th 19, 04:19 PM posted to rec.aviation.soaring
So the pedals can be adjusted without changing the cable length.
On pre flight it is good to move the pedals for and aft and look at the cables. Sometimes the cables will fray at the entry and exit points of the S-tubes.
J Banks
Old May 11th 19, 06:28 PM posted to rec.aviation.soaring
Correct.
If adjusting rudder pedal setting a lot, not a bad idea to run pedals through full range of movement and check cables for wear (during preflight checks) as well as some lube (3&1, silicone, whatever....depends on what the service manual states....).
Old May 13th 19, 03:21 AM posted to rec.aviation.soaring
Let me add one little tid-bit, here. The rudder cables enter the top of the S tube and exit at the bottom, then forward to a cable anchor point. The angle of the rudder pedals can be adjusted by making the cables longer (some pilots prefer pedals that lean forward, rather than sitting straight up). A simple way to lengthen the cables is to add a 1” steel carabiner in the system between the cable end “eye” and its anchor point. Check the new pedal position to see if you prefer it and don’t forget to check that full rudder can still be achieved with the new forward pedal position.
You may find you like it, I did!
JJ
Old May 13th 19, 07:32 AM posted to rec.aviation.soaring
The lower exit of the S tube should be on the axis of rotation of the rudder pedals so that when the rudder is used the distance between the exit and the forward attachment point stays the same. If not the cable slides slight to and fro through the S tubes giving the prospect of wear especially if there is no plastic sleeve insert extending out of the tube - worse still if the ends of the tube are sharp and not bell-ended. Schempp-Hirth gliders have this right as the exit is on the rotation axis outboard of the axle. Most other makes have the lower part of the S tube welded to the vertical of the pedal some close and some not so close to the axis. At least one design has the tube exit projecting forward from the pedal so that not only does the cable move in the S tube it is also angled slightly on full rudder deflection.
Old May 13th 19, 08:18 AM posted to rec.aviation.soaring
krasw
JJ
What an awful advice. Fiddling with control system in first place, and secondly rudder pedals would hit cockpit wall almost certainly in forward position when pushed to limit. Please don't never ever do this.
Old May 13th 19, 02:44 PM posted to rec.aviation.soaring
JJ
An AN 115-21 cable shackle will accomplish this also using a standard aircraft part. It gives about 3/4 inch extension. The only other part needed is an AN 393-11 clevis pin with cotter pin for retention.
UH
Old May 13th 19, 10:11 PM posted to rec.aviation.soaring
65 years ago a Boeing Tec-Rep told me; “Aircraft were designed by geniuses to be operated by idiots”! Looks like nothing much has changed at Boeing.
Questioning a manufactures design decisions is not a bad thing, even with something as simple as altering rudder pedal angle.
JJ
Old May 16th 19, 08:25 AM posted to rec.aviation.soaring
krasw
JJ
Yes it is. Rudder, cables and springs are a system that has eigenfrequency. They can and will flutter at some point. I bet next someone will come up with idea that you can actually cut off the control stick and welding a steering wheel in place. So much more comfortable to fly!
Old May 16th 19, 04:28 PM posted to rec.aviation.soaring
My experience and training tell me rudder flutter is caused by rudder imbalance and sometimes slop in the hinges or drive. It has nothing to do with rudder pedal angle! I know of 346 people and a whole bunch of airline pilots that wish someone had questioned Boeing’s design decisions on the 737 Max.
JJ
Antares rudder pedal dimensions sisu1a Soaring 1 March 22nd 18 04:38 PM
Discus Rudder Pedal Adjustment [email protected] Soaring 3 February 26th 16 05:11 PM
rudder pedal springs Dick[_1_] Home Built 6 May 20th 08 07:23 PM
Need Grob 103 Twin II left front rudder pedal Mike McCarron Soaring 1 May 15th 06 02:16 PM
Piper Rudder Pedal Pads Mike Spera Owning 1 November 4th 05 03:31 AM
