Cambridge variometer
Old January 13th 05, 11:39 PM
f.blair
Default Cambridge variometer
I don't know that model number, but it is the vario that comes with the
L-Nav system. Does anyone know how to open it and adjust the needle
position. Mine is now showing 2 kts up.
Fred
Old January 13th 05, 11:59 PM
Fred
Just crack your spoilers open a little when you are flying, that should
fix the problem.
Old January 14th 05, 04:44 AM
Paul Remde
Hi,
It is possible to do basic calibration using the L-NAV LCD display screen
(the main unit). The online L-NAV demo I created a few years ago says:
"Hold the GO key and LEFT or RIGHT arrow key to go to the Configure,
Calibrate and Defaults screens."
Then press the left button until the screen says "Calibrate" and press the
Go button.
Then press the right button until the screen says "Variometer".
Then use the up and down arrows to adjust the offset.
If that doesn't work you may have to send it to CAI for calibration.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"f.blair" wrote in message
ink.net...
Fred
Commercial - Updated Cambridge 302A Paul Remde Soaring 2 December 16th 04 08:35 PM
Cambridge Instruments Ian McPhee Soaring 2 June 18th 04 11:14 AM
Cambridge Aero Explorer Fix Guy Byars Soaring 8 May 19th 04 04:04 AM
Updated IGC approval documents for Cambridge GNSS flight recorders Ian Strachan Soaring 0 August 27th 03 06:28 PM
Cambridge Aero Instruments Ulrich Soaring 6 August 7th 03 06:48 PM
