MMIST CQ-10 Snowgoose
Old September 27th 18, 02:56 PM posted to alt.binaries.pictures.aviation
Miloch
Default MMIST CQ-10 Snowgoose
https://en.wikipedia.org/wiki/MMIST_CQ-10_Snowgoose
The MMIST CQ-10A SnowGoose is a cargo delivery unmanned aerial vehicle that has
reached IOC (Initial Operational Capability) with the United States Armed Forces
with the delivery of 15 vehicles. The SnowGoose UAV is produced by the Canadian
company Mist Mobility Integrated Systems Technology (MMIST). The SnowGoose UAV
is an application of MMIST's Sherpa autonomous GPS-guided parafoil delivery
system and is intended for pin-point delivery of small cargo items (ammunition,
supplies) to special forces. A fully loaded Snowgoose can carry a total of 600
lb. The SnowGoose was originally designed for leaflet dispensing, but can
support a variety of missions with its six modular cargo bays, each of which can
carry pods for fuel (trading payload for range), cargo, or electronics (sensor
or broadcasting) packages.
The CQ10A uses a parafoil for lift; the CQ10B uses an autogyro rotor for lift.
The "B" version has twice the range of the "A" version. According to the
manufacturer, the CQ10B can carry 1088 kg (2400 lb) up to 150 km (93 mi) from a
central base per day (24 h), placing the loads within 30 m (100 ft) of a
predesignated point then performing near-vertical take-offs.
Role
Unmanned Aerial Vehicle (UAV)
Manufacturer
MMIST
First flight
April 2001
Introduction
January 2005
Primary user
USSOCOM
Number built
CQ-10A: 15 (49 planned)
Variants
CACQ-10A Parafoil lift.
CQ-10B Autogyro rotor lift with increased range. VSTOL.
Specifications
Length 2.90 m (9 ft 6 in)
Wing Span: 2.1 m (6 ft 8 in)
Weight max: 635 kg (1400 lb); empty: 270 kg (600 lb)
Cargo weight max: 272 kg (600 lb) ("A" version) / (227 kg) (500 lb) ("B"
version)
Engine: Rotax 914 piston engine; 81 kW (110 hp)
Range: 300 km (160 nmi) (34 kg (75 lb) payload)("A" version) / 600 km (320 nmi)
("B" version)
Endurance: 19 hrs
Speed: 61 km/h (38 mph)("A" version) / 120 km/h (75 mph ("B" version/ est.)
Ceiling: 5500 m (18000 ft)
