LS3A flap/aileron mixer
Old May 19th 19, 05:11 PM posted to rec.aviation.soaring
RV 6 Driver
Default LS3A flap/aileron mixer
I am doing an annual inspection on a LS3A and have some concerns regarding the flap/aileron mixer. Just wondering if anybody has any knowledge on proper rigging procedures for this. I have the maintenance manual but it does not address this issue. All I get out of the manual is the deflections and tolerances for the ailerons in a given flap position. I am hoping that there are rigging pins for this but I just don't know. Any help would be appreciated.
Old May 19th 19, 06:15 PM posted to rec.aviation.soaring
Never found anything in writing, but when I had a 3 that didn’t fly straight, I set the ailerons to match the wing tip fairing, then set the flaps to match the inboard end of the ailerons. Then I checked for semidry in all flap positions. Ship flew straight after that.
Hope this helps,
JJ
Old May 19th 19, 06:59 PM posted to rec.aviation.soaring
Start with the flaps in zero and the stick in the middle. If the ship has seen major trauma, the stick may not be in the middle which is adjusted at the bottom of the stick. All flap angles must be the same left and right, I wouldn’t worry too much about the exact book angle, as long as they both read the same.
JJ
Old May 20th 19, 01:12 AM posted to rec.aviation.soaring
RV 6 Driver
Thanks JJ! I will take a look at it a 0 flaps
Old May 20th 19, 01:53 AM posted to rec.aviation.soaring
Charlie Quebec
I got laser cut templates and accurately marked the neutral point and deflection limits. Worked great.
Old May 20th 19, 07:28 PM posted to rec.aviation.soaring
Roger on the 20 which is even better because you have the end of the aileron as a reference and the flap/fuselage fairing as another reference point. I have found adjustments that were made to stop a turning tendency by cranking one aileron up or down to stop the turn, but that doesn’t work! Both ailerons will equal out the new setting by flying up (or down) a tad and the turn remains. The only way to stop a turn is by installing a small trim tap, bent up or down in the direction indicated.
JJ
Old May 20th 19, 05:50 PM posted to rec.aviation.soaring
Charles Longley
JJ do you think the same will work for an ASW-20? The ship I just bought had major trauma in the past.
Old May 20th 19, 06:03 PM posted to rec.aviation.soaring
JS[_5_]
Seen it used on ASW12 after the flap mod, and Ventus B (while becoming a C).
Old May 20th 19, 06:53 PM posted to rec.aviation.soaring
BobW
Short of having the manufacturer's jigs available, "It's the best you can do."
Each ship, after all, was created *from* those jigs (& molds), and arguably
represents the best the manufacturer could do at the time each ship was built.
In piece part terms, the "core of the fuselage" (i.e. the wing root area)
arguably is going to be the most stable bit pulled from any mold, and as such
"naturally" becomes a reference base from which to measure (and set)
everything else...which is what JJ's method does. You gotta start SOMEwhere!
Have at it, and good luck!
Bob - former modeler/ex-aerospacey-engineer - W.
This email has been checked for viruses by AVG.
https://www.avg.com
Rolladen- Schneider LS3A flap seals- Do they really make any difference? [email protected] Soaring 0 April 8th 18 05:44 AM
Rolladen- Schneider LS3A flap seals- Do they really make anydifference? Dan Marotta Soaring 0 February 19th 18 04:39 PM
Rolladen- Schneider LS3A flap seals- Do they really make any difference? [email protected] Soaring 9 February 19th 18 01:50 AM
FA: M18B Dromader Flap & Aileron BFC Aviation Marketplace 0 September 24th 04 04:29 PM
Flap/aileron don't line up -- always a problem? Ben Jackson Owning 4 April 13th 04 01:53 AM
