Can you swap Tost hook levers?
Old May 20th 19, 10:37 PM posted to rec.aviation.soaring
soaringjac
Default Can you swap Tost hook levers?
Can you swap out the levers on Tost hooks? For example taking a standard lever off and replace it with a short lever. Or taking a short lever off and putting it on a hook with no lever
Old May 21st 19, 12:08 AM posted to rec.aviation.soaring
JS[_5_]
Yes.
Old May 21st 19, 12:30 AM posted to rec.aviation.soaring
soaringjac
Yes.
Looks like the inner most bold holding on the lever has the spring and all that around it. if you take that out it seems like you pretty much have to rebuild the thing with the spring loading. not sure if thats wise or something we should be messing with? It for sure looks doable, just not sure about doing it.
Std. 2 Jantar - CG Tost hook? [email protected] Soaring 6 November 28th 17 10:11 AM
Looking to buy Tost hook [email protected] Soaring 2 March 4th 17 02:02 PM
Tost tow hook STC for C-182 ? [email protected] Soaring 6 September 27th 16 02:13 AM
Cessna 185 with a Tost hook? Nimbob Soaring 1 September 29th 09 01:43 PM
Tost hook on Cessns 180 Paul Soaring 6 October 18th 04 11:32 PM
