Real Costs of operation
Old August 20th 04, 12:09 AM
Default Real Costs of operation
I'm trying to get a good objective reading on what the actual hourly
cost is to operate a Kitfox, Avid, or RANS type aircraft with a Rotax
912/14 and 582. I know what it is to overhaul the engines, but I need
feedback from someone who has actually recorded the information and
can give me imperical information. Any takers???
Old August 20th 04, 08:32 AM
Roger Halstead
I can't give you the figures for the Kitfox, but I can tell you that
you should figure the cost the way the FBO does and not rationalize
away part of the costs. Use everything, insurance, hanger,
maintenance, overhaul (averaged per hours), as well as gas and oil.
IOW take the *entire* cost of owning per year and then divide by the
hours you fly or plan to fly.
Quite a few do not figure hanger, insurance, and payments (or at least
interest), but if you didn't have the plane you wouldn't have the
costs.
Only when you sell it can you figure the difference between the
acquisition cost and what you get back In some cases it's a positive
figure.
I didn't have any interest so I can take the increase in value (if
any) when I sell the plane and then average it over the number of
hours flown and hopefully subtract it. To get the actual hourly cost
for owning and flying the plane for however many years I have kept it.
So, if I flew 1000 hours and sold the plane for 20,000 over what I
paid I could subtract $20 per hours from the flying cost. OTOH that is
not realistic while you are flying the plane. If you keep it for 10
years and fly 100 hours per year that extra $20 per hour subtracted at
the end really has no effect while you are flying.
As a "Wild Assed Guess" (WAG), I'd guess the Kitfox would run between
$20 to $30 per hours. We were flying a Cherokee 180 at $37 per hour
with 5 people flying it. Flying 130 hours per year the Deb was costing
me $79 per hour.
www.rogerhalstead.com
Old August 21st 04, 08:59 PM
Roger Halstead
On Fri, 20 Aug 2004 03:36:15 -0500, Barnyard BOb -
On Fri, 20 Aug 2004 07:32:43 GMT, Roger Halstead
me $79 per hour.
Roger Halstead
WAG is right.
Not enuff specific info from mike, because...
If the annual total costs are $2000 and you fly one (1) hour...
That COULD be $2000 an hour.
Amen!
As you say below, add insurance, hanger, interest... Of course for one
hour the gas and oil *should* be almost negligible compared tot he
other expenses.
Actual figures: Let's see. Insurance $1700, hanger 140/month=
1680/year and the annual ran $1750 this year, for $5130 fixed costs.
14 GPH at $2.80 = $39.2
So one hour would run me $5169.20.
10 hours drops the cost 5522/10=$552.20/hour
and 100 hours = $9050/100= $90.50 per hour.
If I could manage to get 130 hours as I flew for most years that is
10,539.6/130=$81.07
I did neglect the oil changes in there, or any likely incidental
maintenance AND the $10 per hour I add for the major. Yearly interest
if any should also be added as it's an expense that you never get
back.
As it costs me nearly $40 per hour for gas and a minimum of $10 per
hour toward the major and an oil change every 25 hours, The variable
cost per hour is a minimum of roughly $55.
Flying my RV-3 under my specific circumstances...
I never have had the hourly cost below $55 an hour
and I fly more than 100 hours a year. If I fly less hours
a year, have the hangar rent, insurance and the time
value of money increase, the hourly cost can rise....
DRAMATICALLY.
Barnyard BOb - over 50 years of flight
Old August 22nd 04, 03:00 AM
Ernest Christley
Roger Halstead wrote:
Amen!
other expenses.
10,539.6/130=$81.07
back.
They type of airplane you have can make a lot of difference. This WAG
is slightly bigger than the other, since I haven't finished building
yet, but....
No insurance. It's a plans built aircraft. No loan, no need for hull
coverage. If I trash the plane, then I'm just back to where I started.
No annual. I'll have the repairman's certificate.
No hanger. The Delta folds up and you take it home with you (No. I'm
not making that up.)
I'm installing a rotary engine. Mogas is cheaper, but still around
$2/gal. My burn rate will be about the same, 8-14gph depending on how
fast I want to go on any particular day.
Overhauls will run between $200 and $5000, depending on what must be
replaced (changing seals to a whole new engine). I'm only counting on
1000hrs TBO. At 100hrs/yr, it'll take 10yrs to to reach TBO. The seals
need to come out then regardless of how well the engine seems to be running.
These numbers will probably be way off. Just a back-of-envelope data point.
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Old August 24th 04, 12:47 AM
I guess I wasn't quite specific enough. I have accounted for the
annuals, overhauls, repairmans certificate, hanger (NOT, I'm going to
fold wings and go home). What I'm really after is actual fuel costs,
oil changes, and a SWAG on repair parts and consumables cost for an
average year. I'm specifically focusing on Rotax four strokes vs
Rotax two strokes. Based on 100 hrs/yr, anyone want to SWAG?
Ernest Christley wrote in message . rr.com...
Amen!
other expenses.
10,539.6/130=$81.07
back.
yet, but....
Old August 24th 04, 05:45 AM
ET
(Mike) wrote in
om:
. rr.com...
Amen!
one hour the gas and oil *should* be almost negligible compared tot
he other expenses.
costs. 14 GPH at $2.80 = $39.2
10,539.6/130=$81.07
interest if any should also be added as it's an expense that you
never get back.
variable cost per hour is a minimum of roughly $55.
WAG is slightly bigger than the other, since I haven't finished
building yet, but....
hull coverage. If I trash the plane, then I'm just back to where I
started.
I'm not making that up.)
how fast I want to go on any particular day.
on 1000hrs TBO. At 100hrs/yr, it'll take 10yrs to to reach TBO. The
seals need to come out then regardless of how well the engine seems
to be running.
point.
I think you need BOTH numbers.
You need the "what did this cost me last year per hour to fly" for the
decision to keep the plane or sell it...
But you also need to know the "what is this going to cost me to fly 2 hrs
to grandma's house and 2 hrs back" for the decision to go see grandma or
just fly an hour around the pattern
Bruce - Aviation wannabe
ET
"A common mistake people make when trying to design something
completely foolproof is to underestimate the ingenuity of complete
fools."---- Douglas Adams
Real World test bed for avionics - Megawatts at Delano MikeremlaP Home Built 0 June 2nd 04 04:24 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Ultralight costs Bob Martin Home Built 1 January 1st 04 09:34 PM
