https://en.wikipedia.org/wiki/Boeing...Q-21_Blackjack
The Boeing Insitu RQ-21 Blackjack, formerly called the Integrator, is an American unmanned air vehicle designed and built by Boeing Insitu to meet a United States Navy requirement for a small tactical unmanned air system (STUAS). It is a twin-boom, single-engine, monoplane, designed as a supplement to the Boeing Scan Eagle. The Integrator weighs 61 kg (135 lb) and uses the same launcher and recovery system as the Scan Eagle. The RQ-21A Integrator first flew on 28 July 2012. On 10 September 2012, the Integrator entered developmental testing with a 66-minute flight. The Navy launched one using a pneumatic launcher and a recovery system known as Skyhook. This eliminates the need for runways and enables a safe recovery and expeditionary capability for tactical missions on land or sea. At the current testing rate, Initial Operational Capability (IOC) was expected in 2013. On 10 February 2013, the Integrator completed its first at-sea flight from the USS Mesa Verde, a San Antonio-class amphibious transport dock. This followed completing three months of land-based flights. On 19 February 2013, Insitu completed the first flight of the RQ-21A Block II. It weighs 121 lb and flew for 2 hours. It was controlled by a new ground control system meant to integrate dissimilar UAV systems. The Block II has the sensor from the Nighteagle, the night version of the ScanEagle, and is designed to operate in high-temperature environments. On 15 May 2013, the Department of the Navy announced that the RQ-21A Integrator received Milestone C approval authorizing the start of low rate initial production. With Milestone C approval, the Integrator entered production and deployment. The RQ-21A Blackjack is designed to support the U.S. Marine Corps by providing forward reconnaissance. A Blackjack system is composed of five air vehicles and two ground control systems. The air vehicles can be launched on land or on a ship by a rail and land using a "skyhook" recovery system, where a vertical wire must be hooked onto its wing; when on the ground, the launch and recovery systems are towable by vehicles. Its wingspan is 16 ft (4.9 m) and it can carry a 39 lb (18 kg) payload. The day/night camera can achieve resolution rating of 7 on the NIIRS scale at 8,000 ft (2,400 m). The Marines are working with Insitu to modify the Blackjack fuselage to carry greater and more various payloads. Enlarging the fuselage would increase its maximum takeoff weight from 135 lb (61 kg) to 145 lb (66 kg) and lengthen endurance from 16 hours to 24 hours. New turrets are being explored as well as other payloads including a synthetic aperture radar to track ground targets, a laser designator to mark targets for precision-guided munitions, and foliage-penetration capabilities for foreign customers operating in lush environments. The Office of Naval Research (ONR) plans to add a sensor to the Blackjack that combines an electro-optical camera, wide area imager, short wave infrared hyperspectral imager, and a high-resolution camera for use as an inspection sensor into a single payload by 2020. Role Unmanned air vehicle National origin United States Manufacturer Insitu wholly owned subsidiary of Boeing Defense, Space & Security First flight 28 July 2012 Introduction April 2014 Status In service Primary users United States Marine Corps United States Navy Number built 109 systems with 5 air vehicles each (estimated through FY2017) Program cost US$559 million (estimated U.S. DoD cost for 104 systems through FY2017) Developed from Boeing Insitu ScanEagle The U.S. Marine Corps deployed its first RQ-21A Blackjack system to Afghanistan in late April 2014. One Blackjack system is composed of five air vehicles, two ground control systems, and launch and recovery support equipment. It supports intelligence, surveillance, and reconnaissance (ISR) missions using multi-intelligence payloads including day and night full-motion video cameras, an infrared marker, a laser range finder, a communications relay package, and automatic identification system receivers. The models in Afghanistan were early operational capability (EOC) aircraft without shipboard software or testing. Deploying the aircraft on the ground was a method to detect and fix problems early to avoid delaying the project. The RQ-21 returned from its deployment on 10 September 2014 after flying nearly 1,000 hours in 119 days in theater. EOC Blackjacks will continue to be used for training, while completion of shipboard testing is planned to result in the system's first ship-based deployment in spring 2015. The Marine Corps declared Initial Operational Capability (IOC) for the RQ-21A Blackjack in January 2016. During the summer of 2016, MARSOC deployed the RQ-21A to Iraq. Full rate productions of the RQ-21A has been delayed because of serious system quality issues. The Office of the Secretary of Defense (OSD) issued reviews on the program in 2013, 2014, and 2015. The 2015 report indicates that many of these issues have not been resolved, despite OSD reporting issues in previous years. The 2015 report stated that the RQ-21A was "not operationally effective", "not operationally suitable", that the "system has exploitable cyber security vulnerabilities, and the overall assessment pointed out several major requirements failures. One RQ-21A was reported shot down over Tartus, Syria on May 27,2017. Specifications General characteristics Length: 8.2 ft (2.5 m) Wingspan: 16 ft (4.9 m) Empty weight: 81 lb (37 kg) Max takeoff weight: 135 lb (61 kg) Powerplant: 1 × EFI Piston Engine, 8 hp (6.0 kW) Propellers: 2-bladed Performance Maximum speed: 86 mph (138 km/h; 75 kn) Cruise speed: 63 mph (101 km/h; 55 kn) Range: 58 mi; 93 km (50 nmi) Endurance: 16 hours Service ceiling: 19,500 ft (5,900 m) * |
Marine RQ-21 Blackjack Drones Are Flying Three Times More Than Expected In Iraq and Syria [4/5] - RQ-21 Blackjack.jpg (1/1) | Miloch | Aviation Photos | 0 | May 15th 18 01:31 PM |
Marine RQ-21 Blackjack Drones Are Flying Three Times More Than Expected In Iraq and Syria [3/5] - RQ-21 Blackjack 3.jpg (1/1) | Miloch | Aviation Photos | 0 | May 15th 18 01:31 PM |
Marine RQ-21 Blackjack Drones Are Flying Three Times More Than Expected In Iraq and Syria [2/5] - RQ-21 Blackjack 2.jpg (1/1) | Miloch | Aviation Photos | 0 | May 15th 18 01:31 PM |
Antonov An-30 pics 2 - RQ-21 Blackjack 2.jpg ... | Miloch | Aviation Photos | 0 | May 15th 18 01:19 PM |
Could Blackjack bombers reach USA? | Mike | Military Aviation | 41 | January 20th 04 06:48 PM |
