https://en.wikipedia.org/wiki/HAL_Tejas
The HAL Tejas is an Indian single-seat, single-jet engine, multirole light fighter designed by the Aeronautical Development Agency (ADA) and Hindustan Aeronautics Limited (HAL) for the Indian Air Force and Indian Navy. It came from the Light Combat Aircraft (LCA) programme, which began in the 1980s to replace India's ageing MiG-21 fighters. In 2003, the LCA was officially named "Tejas". Tejas has a tail-less compound delta-wing configuration with a single dorsal fin. This provides for high maneuverability. Its wing root leading edge has a sweep of 50 degrees, the outer wing leading edge has a sweep of 62.5 degrees, and trailing edge has a forward sweep of four degrees. It integrates technologies such as relaxed static stability, fly-by-wire flight control system, multi-mode radar, integrated digital avionics system, composite material structures, and a flat rated engine. It is the smallest and lightest in its class of contemporary supersonic combat aircraft. The Tejas is the second supersonic fighter developed by Hindustan Aeronautics Limited (HAL) after the HAL HF-24 Marut. As of 2016 the Tejas Mark 1 is in production for the Indian Air Force (IAF) and the naval version is undergoing flight tests for Indian Navy (IN). The projected requirement for the IAF is 200 single-seat fighters and 20 twin-seat trainers, while the IN expects to operate 40 single-seat fighters. The first Tejas IAF unit, No. 45 Squadron IAF Flying Daggers was formed on 1 July 2016 with two aircraft. Initially being stationed at Bangalore, the first squadron will be placed at its home base at Sulur, Tamil Nadu. The Minister of State for Defence, Subhash Bhamre, reported to parliament that the indigenous content of the Tejas is 59.7% by value and 75.5% by number of line replaceable units. In 1983, IAF realised the need for an Indian combat aircraft for two primary purposes. The principal and most obvious goal was to replace India's ageing MiG-21 fighters, which had been the mainstay of the IAF since the 1970s. The "Long Term Re-Equipment Plan 1981" noted that the MiG-21s would be approaching the end of their service lives by the mid-1990s, and that by 1995, the IAF would lack 40 percent of the aircraft needed to fill its projected force structure requirements. The LCA programme's other main objective was an across-the-board advancement of India's domestic aerospace industry. The value of the aerospace "self-reliance" initiative is not simply the aircraft's production, but also the building of a local industry capable of creating state-of-the-art products with commercial spin-offs for a global market. Project definition commenced in October 1987 with France's Dassault-Breguet Aviation as consultants. Dassault-Breguet were to assist in the design and systems integration of the aircraft, with 30 top-flight engineers reported to have flown to India to act as technical advisers to IADA, in exchange for $100m / ?560 crore (equivalent to ?50 billion or US$690 million in 2017), this phase was completed in September 1988. National origin India Manufacturer Hindustan Aeronautics Limited (HAL) Design group Aeronautical Development Agency First flight 4 January 2001 Introduction 17 January 2015 Status In service Primary user Indian Air Force Produced 2001–present Number built 26 (including prototypes as of July 2018) Program cost ?7,399.69 crore (US$1 billion) (LCA total in 2015) Unit cost ?162 crore (US$23 million) for Mk 1 ?463 crore (US$64 million) for Mk 1A The formation of the first Tejas-equipped squadron started in July 2011. The Tejas entered service with No. 45 Squadron IAF (Flying Daggers) based at the Yelahanka Air Base at Bangalore on 1 July 2016 before being moved to Sulur Air Force Station in Coimbatore. The squadron will initially have four aircraft. The IAF's Aircraft & Systems Testing Establishment will receive four aircraft already built including two development aircraft. The Tejas made its international debut on 21 January 2016, when two aircraft flew in the Bahrain International Air Show. On 21 November 2016, the Indian Ministry of Defence said that they're proposing to have the Tejas exported with preliminary talks taking place with some friendly countries. In June 2017, Hindustan Aeronautics stated that it expects to have delivered 123 Tejas aircraft to the Indian Air Force by 2024–25. HAL outlined a three–pronged approach to accelerate aircraft production. It will build an additional assembly line, reuse the Hawk assembly line, and outsource major components to the private sector. Specifications (HAL Tejas Mk 1) General characteristics Crew: 1 Payload: 3,500 kg (7,716 lb) external stores Length: 13.20 m (43 ft 4 in) Wingspan: 8.20 m (26 ft 11 in) Height: 4.40 m (14 ft 9 in) Wing area: 38.4 m² (413 ft²) Empty weight: 6,560 kg (14,300 lb) Loaded weight: 9,800 kg (21,605 lb) Max. takeoff weight: 13,500 kg (29,100 lb) Internal fuel capacity: 2,458 kg External fuel capacity: 2 x 1,200-litre drop tank inboard, 1 x 725-litre drop tank under fuselage Powerplant: 1 × General Electric F404-GE-IN20 turbofan Dry thrust: 53.9 kN (12,100 lbf) Thrust with afterburner: 89.8 kN (20,200 lbf) Performance Maximum speed: Mach 1.8 (2,205 km/h); Mach 1.6 (2,000 km/h) for IOC version; Range: 850 km (459 nmi, 528 mi) Combat radius: 500 km (270 nmi, 310 mi) with drop tanks Ferry range: 1,750 km (1,087 mi) with drop tanks Service ceiling: 16,000 m (52,500 ft) Wing loading: 255 kg/m² (52 lb/ft²) Thrust/weight: 0.96 g-limits: +8/-3.5 g Armament Guns: 1× mounted 23 mm twin-barrel GSh-23 cannon with 220 rounds of ammunition Hardpoints: 8 (1× beneath the port-side intake trunk for targeting pods, 6× wing, and 1× fuselage) with a capacity of 3,500 kg external fuel and ordnance and provisions to carry combinations of: Rockets: S-8 rocket pods (expected) Missiles: Air-to-air missiles: Derby Python-5 (expected) R-73 Air-to-surface missiles: Kh-59 (expected) DRDO Anti-Radiation Missile (expected) Anti-ship missiles: Kh-31 (expected) Kh-35 (expected) Bombs: Laser-guided bombs Glide bombs Cluster weapons (expected) Other: Drop tanks for ferry flight/extended range/loitering time LITENING GR4 targeting pod Avionics Hybrid version of Israel's Elta EL/M-2032 multi-mode fire control radar * |
| Thread Tools | |
| Display Modes | |
