XCSOAR .igc filename question
Old June 8th 19, 05:54 AM posted to rec.aviation.soaring
Default XCSOAR .igc filename question
Can someone please explain to me why the XCSOAR for android program always uses the serial id of "AAA" in the filenames for the .igc file it creates?
From page 18 of the 31 May 2019 IGC GNSS FR Technical Specification:
Long file name: 2015-06-17-MMM-XXX-02.IGC
MMM = manufacturer's three-letter IGC identifier (see table on next page)
XXX = unique FR Serial ID (S/ID); 3 alphanumeric characters
02 = second flight of the day
So according to the IGC specification, the Manufacturer's 3 letter IGC identifier and the unique FR serial ID should produce a unique file name. However, XCSOAR does not output a unique Serial ID, it always outputs "AAA". For example:
2019-06-07-XCS-AAA-01.igc
The problem arises if more than one pilot at a contest is using XCSOAR, then the scorer will receive .igc files from different pilots with identical filenames.
Is there anyway for the pilot to configure XCSOAR to output a serial ID other than "AAA"?
Old June 8th 19, 07:46 AM posted to rec.aviation.soaring
SoaringXCellence
Use your Contest ID, filled with 0s as needed, or the last three letters of your registration number.
I'm a contest scorer and I have a program that reads the pilot name from the IGC file even if the names are the same. YMMV
Top Hat Question (XCSoar?) [email protected] Soaring 47 October 29th 18 12:56 AM
XCSoar Question Dan Marotta Soaring 9 June 16th 16 03:58 PM
CAI-302 and XCSoar Dan Marotta Soaring 7 March 29th 12 10:55 PM
XCsoar 6.2.6 Question Karl Kunz Soaring 8 March 16th 12 05:12 PM
XCSoar in the UK Martin Gregorie[_5_] Soaring 0 August 10th 09 11:46 PM
